Increase timeout foward external call
Discussion in '3CX Phone System - General' started by Daniel Sant Anna, Nov 30, 2017.
  1. Daniel Sant Anna
    Feb 12, 2017
    10
    Hello there,
    We have been losing several calls on the 3cx ISO app. Regarding external calls, I want to increase the time before calls to be foward to voicemail.
    thanks!
  2. pmterp
    Jun 13, 2017
    54
    10
    Go to Forwarding Rules for the extension and change the timeout amount listed under the Internal Calls section. Even though it is in the Internal Calls section of the page, the same timeout is used for external calls.
  3. apostolis_3CX
    apostolis_3CX Support Team
    Nov 1, 2017
    149
    15
    Hello Daniel Sant Anna,
    As pmterp mentioned increasing the time for the forwarding rules to activate will do the trick. Please ensure that all 4 possible destinations (2 for internall and 2 for externall calls) are configured as desired for each case. If the externall calls are being directed to a queue or a ring group then the maximum queue wait time or the ring time should be changed accordingly.
    vizualpro likes this.
  4. Daniel Sant Anna
    Feb 12, 2017
    10
    Thanks everybody!
