indanpendance
Discussion in '3CX Phone System - General' started by sata, Aug 29, 2007.
  1. sata
    Jul 16, 2007
    22
    i have a bad echo on my line only when i try and dial out dose any body know what the indanpendance is for the uk so i can set up my grandstream fxo gatway?
  2. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    For Linksys PAP2 my manual says "FXS Port Impedance: 370+620||310nF" - hopefully there is a comparable setting in your adapter. You will also need to tweak Gain settings for echo.
    P.S. The value given above is UK specific I believe.
