Indentify Ring Tones
Discussion in '3CX Phone System - General' started by djsuperstore, Feb 28, 2008.
  1. djsuperstore
    Feb 20, 2008
    25
    Is it possible to change the ring tones on the Snom 300 ip phones so you can tell if the call is internal or an incomming call from a voip line?
