Independent E911 CID
Discussion in 'Ideas' started by Brad Allison, Oct 29, 2017.
Independent E911 CID 4 5 2votes
4/5, 2 votes
  1. Brad Allison
    Jun 7, 2017
    67
    20
    Currently there is only a single Outbound Caller ID, a secondary Outbound Caller ID that would just be for 911 purposes would be helpful.
    When left blank the main line CID would be used.
    The purpose of this would be E911, whether it be room based, tenant based, branch based the Outbound CID and the E911 CID should be able to be separated out.
  2. the60
    the60 New Member
    Oct 21, 2011
    117
    61
    set up a special 911 trunk.
    specify (hard code) the outbound DID in it.
    set up an outbound rule, 3-digit length, starts with 9 (for test calls to 933)
    move the rule to the top of the outbound rule list.
    If multi-location client, set up extension groups as well.
  3. Silly English Kniggit
    Sep 13, 2017
    220
    89
    As @the60 says - use a separate trunk, or a trunk per location. I'm currently doing this for 15 offices in 5 countries for a client - the provider required us to use a trunk per location before they would enable emergency calling. This has the added benefit that calls for each office (trunk) are accounted for separately. Does mean we have a lot of outbound rules though!
  4. Brad Allison
    Jun 7, 2017
    67
    20
    The per location trunk works to identify smaller deployments for where the 911 originated from by location..
    When dealing with a company that need to be able to identify down to the T ( Location A, Floor 3 ) or (Location B, Office 709)
    Obviously that will add up a lot of trunks just for E911 purposes really quick.
    If the SIP Trunk providor requires a separate trunk per E911 location then i'd purpose 3CX automate the creation of the SIP Trunk.
    Put a E911 CID under each extension, then a drop down of programmed SIP Trunks to choose from, once these fields are filled out it will create the SIP trunk based off the selected SIP Trunk. maybe create a whole new section just for E911 SIP Trunks?
  5. simply7
    Jan 4, 2016
    39
    19
    #5 simply7, Jan 31, 2018
  6. voiptoys
    voiptoys Active Member
    Feb 13, 2013
    893
    154
    If you want to have 911 notifications down to the building, floor, pillar, and cubicle, take a look at our 3CX Emergency (911) notifier. You can upload location information to your telecom provider to give precise location information. Further we can send notifications via phone (text-to-speech), email, SMS, and desktop alerts. We also offer panic buttons and continuous alarms as BLFs on your VoIP phone. https://www.VoIPTools.com
  7. simply7
    Jan 4, 2016
    39
    19
    But why would I want to put a monthly add on for only one item out of your suite? The 911 items should be built in to the system just like every other PBX out there. This should not only be achievable by leveraging 3rd party tools.
    Brad Allison likes this.
  8. Brad Allison
    Jun 7, 2017
    67
    20
    I'm curious on how one "uploads" the information to their telecom provider, and then the telecom provider know where the location of the call is coming from to route to the proper PSAP without transmitted E911 CID per extension?
    I see the VoIPTools 3CX Emergency (911) notifier being a great asset for internal emergency handling, but I do not understand how it would help once the call is external.
    #8 Brad Allison, Feb 1, 2018
  9. Brad Allison
    Jun 7, 2017
    67
    20
    Agreed this should be built in like other PBX.
  10. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    304
