Indirizzo IP locale per 3CX
Discussion in '3CX Phone System - General' started by tecnoinfo, Feb 5, 2017.
  1. tecnoinfo
    Feb 5, 2017
    7
    Ho installato 3CX su un PC in una rete locale. Ho poi trasferito il PC su una altra rete
    con indirizzi ip diversi. Nel provisioning dei telefoni la URL indica sempre l'indirizzo IP
    della prima rete.
    Qualcuno sa come risolvere il problema?
    Grazie
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,405
    274
    You do not say what you did and did not try to fix this.
    does pbx have a static ip on the local network?
    does settings -> network show the correct local IP?
  3. GiannosC_3CX
    GiannosC_3CX Guest
    Hi tecnoinfo,
    Take a backup without including license and FQDN un-install and re-install using the correct internal IP address.
    Note: Be careful with the backup file, you need to transfer to new location in order to avoid remove it during un-installation.
