Information on configuration without web interface
Discussion in '3CX Phone System - General' started by rejeansenecal, Aug 27, 2009.
  1. rejeansenecal
    Aug 27, 2009
    Is it possible to configure the 3CX phone system with other means that the web user interfaces? We would like to change extension or ring group via a programming interface. Is there a web service documented or other ways to change setting beside the web interface.
    Thanks. :?:
  2. tpinnovations
    tpinnovations Member
    Jul 30, 2009
    296
    Sure, In theory you could change the settings in the database using pgadmin and reboot the services from telnet. I don't think anyone has ever tried it, But it should work.
