Informational System
Discussion in '3CX Phone System - General' started by bboyd, Jun 5, 2012.
  1. bboyd
    Nov 29, 2009
    23
    We are a trucking company and we are trying to make something work with 3cx that will allow for drivers to call in and check information for their unit.
    The only way I can figure out to do is to to create a voicemail box for each unit (501,502,503,...) and change the greeting to what it should be. Has anyone successfully done something like this before?
    11,073
    323
    They could call in to a number directed to the voicemail system, enter their extension number and PIN and then retrieve a message left in their mailbox.
    It doesn't have to be done with the outgoing message.
    Access could be through an option in an automated attendant.
    Leaving a message would mean simply calling the extension number and recording the information. They could the receive an email (on their mobile?) telling them that a message was waiting.
