Initial impressions
Discussion in 'iOS' started by nevets429, Sep 15, 2010.
  1. nevets429
    Feb 11, 2010
    6
    First impressions are good with the app. A couple suggestions:
    1. Support for the tunnel is necessary for remote users. Most of us choose not to open our SIP ports to the outside world so while away from the office the app can't connect.
    2. Status shows "Available" on screen always. I'd thought maybe if we set the extension status to away or out of office this would change but it always says "Available" and that is it. Doesn't seem to be a way to change it from inside the app either.
    3. Contacts, it shows the full list of contacts - can it have an option to switch to favorites for instance? Have several hundred people in my phone book but when I'm using this app would only be calling those in my favorites most likely.
    4. Dialing a number from the phone book either crashes the app or it dials and immediately hangs up. I thought this was because there was no "9" in the phone book entries but even when I put a four digit extension in the problems persisted. If I dial them by hand on the keypad it's fine.
    5. Additionally, I just noticed that even though a bluetooth headset is registered with the phone and works with other SIP phones, the app won't let me send the call to headset.
    Phone is a 3g with 4.1 on it, non-jailbroken and the app shows v1.0.11 on it. Only have been able to test via Wifi because of no tunnel support right now.
  2. StefanW
    Jun 2, 2009
    1,199
    79
    thx for the test,
    1.
    planed for the future
    2.
    3.
    i will add to a feat list, and see
    4.
    do you have an exchange adressbook or mobile me? or only a local normal iPhone one?
    5.
    pland for future
    Thx for ur time and featback
  3. nevets429
    Feb 11, 2010
    6
    The answer to 4 is a local phone book only, Synch'd to Google contacts, but as far as 3cx is concerned - it's local only.
  4. StefanW
    Jun 2, 2009
    1,199
    79
    unfo. it is not, only when the phone book is not attached to any other service (the DB Name Change) we can not read it for the moment...
