Insert autom. a comma after URL
Discussion in '3CX Phone System - General' started by pat, Feb 12, 2008.
  1. pat
    pat
    Feb 12, 2008
    34
    i together
    i download yesterday the version 5.1 and install it.
    now after i login and try to configure something. after i click on a link (URL) it has always a comma "," behind the URL in the browser.
    So the Page can't load! i delete the comma behind the URL and the page runs ok.
    Do you know some Problems like this?
    Thanks for your Help.
    Pat
  2. matthijsolislagers
    matthijsolislagers New Member
    140
    Hi Pat,
    I don't experience the same problem. I use Internet Explorer 7. Perhaps the problem is broweser related. What browser do you use?
  3. pat
    pat
    Feb 12, 2008
    34
    Hi matthijsolislagers
    I use the IE7. So i will test it withe the Firefox tonight.
    Pat
  4. matthijsolislagers
    140
    That is the same as I use. So I think we should try to find a solution elsewhere.
    Did you do much configuration? Otherwise you could reinstall 3CX completely. It seems to me like a strange problem, maybe a Apache issue?
  5. matthijsolislagers
    140
  6. pat
    pat
    Feb 12, 2008
    34
    No. I has not config so much, still testing 8)
    I will re-install it and try again.
    i will tell you more tonight...
    pat
  7. pat
    pat
    Feb 12, 2008
    34
    so i login now again, and all working fine :roll:
    i don't know why, perhaps the reboot....
    sorry, but thanks for your help!
    pat
