Inserting SSL certificate and private key for Secure SIP not working
Discussion in '3CX Phone System - General' started by sip.bg, Sep 18, 2017.
  1. sip.bg
    sip.bg Active Member
    Nov 7, 2016
    704
    219
    Seems not possible to insert the private key in Secure SIP section is Settings | Security. The certificate file is pasted OK, but key file is pasted only partially, not the whole file.
    Is this a problem with encryption depth (i.e. 256-bit or more), or is a bug in design (v.15.5) ?
    This used to work with V.14.
    Can wildcard certificate be used too ?
  2. GiannosC_3CX
    GiannosC_3CX Guest
    Hello sip.bg,
    This is a known issue which has already been resolved and will be included in the upcoming service packs.
