- Joined
- Nov 21, 2016
- Messages
- 17
- Reaction score
- 0
I was not able to post a question in docs: http://www.3cx.com/docs/insightly-crm-integration/ so instead writing here for others to join.
3CX PRO/ PC / Windows 7 Pro / Insightly CRM
Problem: 3CX client->Advanced->Integration->Insightly
A) Lookup order does not get saved.
B) When 3CX Client has ‘Import Contacts’ sync’ed with Google account, then incoming calls from persons not in Google Contacts [3CX's address book] – CRM plugin does not get triggered
C) Journaling - Inbound & Missed calls saved in Notes. But Notes about Outbound calls to contacts in CRM don't get saved.
Reason - wrong phone format passed to API. CRM phones are in this format: XXX-XXX-XXXX. Inbound calls are formatted by Vitelity Trunk in same format.
To fix this, we need to add phone formatting option in Integrations.
API log: ...\AppData\Roaming\3CXPhone for Windows\Logs\Insightly.log
Outgoing Call not saved in CRM Notes:
Incoming Calls saved in CRM Notes:
[11.. changed here for privacy]
Code:
11/27/16 1:12:11 PM Error storing call information: contact with phone number '1111111111' could not be found.
Code:
11/26/16 5:19:31 PM - Searching URL = https://api.insight.ly/v2.2/Contacts/Search?phone_number=111-111-1111 ...
