inst on server 2003 failed
Discussion in '3CX Phone System - General' started by Anonymous, Oct 1, 2006.
  1. Anonymous
    Anonymous Guest
    service 3cx phonesystem terminates with message:
    could not start 3cx phonesystem
    error 1067: process terminated ubexpectedly
    i've tried to install it on a 2003 server because the same service did not start ob xp workstation - so both 2003 and xp do not start
    config can be done but do not register because this service is not running
    only mg in server status:
    19:07:23.015 >>> Log started >>>
    19:07:23.031 SessionMgr::run ** Adding transports **
    Any idea?
  2. Anonymous
    Anonymous Guest
    Do you have Live Communications Server installed and running? I do and I have an identical fault.
  3. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    On XP have you tried to add the EXe related to the services to the Firewall expcetions?
    On 2003 try adding the same EXE's to the DEP list.
  4. Anonymous
    Anonymous Guest
    i've disabled the firewall but problem still the same
  5. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    2,004
    308
    Check if another software is using port 5060
    Usually this happens when port 5060 is still in use. I suggest closing down all applications, then restarting the machine. Try to restart the phone system service. If it fails again, check if some software is using port 5060. You can do this by trying to connect to the port using telnet and see if you get a response. If you do, some other software is using the port and 3cx phone system would not start
