Install failure
Discussion in '3CX Phone System - General' started by malackamalac, Dec 9, 2007.
  1. malackamalac
    Dec 9, 2007
    Hi everybody!
    I have a problem...
    When I'm installing the "3CXPhoneSystem5.exe" file, a few sec, and the next popup window come up:
    "Supported Operating System are the following:
    Windows XP SP2 or later..."
    I have a Windows XP SP2, I don't understand, why don't run the setup procedure.
    Can somebody help me?
    Thanx for help, bye!
  2. bhavank
    bhavank New Member
    Apr 24, 2007
    109
    do you have all the latest update patch for windows xp installed. please try and update windows and then try installing again.... please let us know any further issue with the same or even if it works out fine let us know...
  3. Mori
    Mori New Member
    Mar 23, 2007
    223
    Just wondering...
    Is it XP Pro or Home?
    I dont have a clue if it makes a difference, but home ed have less options on LAN and domains.
  4. Pentangle
    Pentangle Member
    Dec 6, 2007
    261
    Nope, XP Home has a 5 computer connection limit for CIFS shares, IIS, printing and remote access.
    http://www.microsoft.com/windowsxp/home/eula.mspx
    See section 1.3 - and an interesting nuance whereby I don't believe "telephony" in this case refers to the use of 3rd party telephony services overlaid onto an XP home license.
    As an aside, you'd be pretty daft to install it on XP Home anyway if you wish to do anything other than basic testing/demoing of the PBX. It has no facilities for redundancy (unless you use it as a guest OS in a VM of course)
  5. malackamalac
    Dec 9, 2007
    Thanx, but I have the solution!
    My operation system is XP SP2 Professional, but Hungary!
    I have installed an english (US) version and everything all right:eek:)
    I think, the installer don't accept international XP...
    English XP and don't worry:eek:)
    Thanx, Bye!
  6. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    This was brought up before. A language issue. Don't recall what country it was but when he went English all was well.
  7. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    The issue is that certain languages report "Windows XP Service Pack 2" instead of "Windows XP SP2". This doesn't agree with our installer. If anyone else has this issue, please pm me.
  8. marck
    Dec 13, 2007
    7
    I have this same error with polish version. When you fix this bug? Yours programm work only english (us) version
  9. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    3CX NOT only support English. :shock:
    It works at Windows Chinese Simplify and Chinese Traditional version as well.
