Install fine, but no sounds
Discussion in 'iOS' started by dimka99, Nov 11, 2010.
  1. dimka99
    Nov 11, 2010
    I have install 3cx phone for my iphone, configured to use my 3CX PBX, can make a call, but have no sounds! can not get any from other party, they can hear me but not me..Please help
  2. Jprice
    Nov 11, 2010
    iPhone 4
    4.1
    3G 1 way audio issues
    Jailbroken w/Limera1n
    I am having the same problems. When using 3G with tunneling, there is no sound delivered to the iPhone. Using WiFi has no sound issues.
  3. dimka99
    Nov 11, 2010
    Any way fo fix it? or i have to ask everyone in company use WiFi
  4. dimka99
    Nov 11, 2010
    install other softphone and it works fine on 3G, 3cx softphone works only on wi-fi 3G no sound received..
  5. StefanW
    Jun 2, 2009
    1,199
    79
    tha answer it not right we work with WiFi and 3G but 3G is not in our controll if the provider support Sip Calls or there routing is not in our hand.
    Thy this on 3CX
    Creat an VPN to the Network via 3G and then just use the internal server path in the app to connect "localy" to the pbx.
    Do you have then audio, then it is 100% sure ur telco is not allowing this.
  6. dimka99
    Nov 11, 2010
    How to fix a problem with no sound(to mobile phone)? from mobile i people can get my voice but i can not get any to my cell
