Solved Install on OVH vps failing
Discussion in '3CX Phone System - General' started by Michael1600, Jun 23, 2017.
  1. Michael1600
    Jun 23, 2017
    26
    Unable to install on new OVH vps server. Able to log in with Putty and loaded the following commands with success:
    wget -O- http://downloads.3cx.com/downloads/3cxpbx/public.key | apt-key add -
    echo "deb http://downloads.3cx.com/downloads/3cxpbx/ /" | tee /etc/apt/sources.list.d/3cxpbx.list
    apt-get update
    This command failed:
    apt-get install 3cxpbx
    Error message is: E: Unable to locate package 3cxpbx.
    Also ran:
    apt-get upgrade
    followed by:
    Still got error:
    Would appreciate some help-Thanks!
  2. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,774
    280
    That error would indicate the 2nd line of commands didn't work or you've somehow mangled your apt configuration. I would try running the second line again:
    And read carefully to make sure it worked. When you run the 3rd command "apt-get update" you should see the 3CX repo listed in the output there. If not, then the 4th command isn't going to work.
  3. Michael1600
    Jun 23, 2017
    26
    Thank you for your help. Re-ran the commands for the third time and it worked. Now up and running. Any tips on managing the OVH Vps and best practices for managing backups?
  4. Bret Gordon
    Jun 16, 2017
    24
    Michael1600 likes this.
  5. Michael1600
    Jun 23, 2017
    26
    Thanks, can you recommend a place to learn about setting up cron jobs to send backup off site?
  6. Bret Gordon
    Jun 16, 2017
    24
    not really, sorry, but:
    1) you need an sftp site to send it to (another linux server that you run)
    2) you need to know where the backup files are (see link in previous post)
    3) you need to add a cron rule to run the command to send those files to the sftp site nightly or however often
    you can google all of this, it's standard linux sysadmin stuff. not trying to be a D
  7. Michael1600
    Jun 23, 2017
    26
    Got it. Thanks again.
  8. Bret Gordon
    Jun 16, 2017
    24
  9. Bret Gordon
    Jun 16, 2017
    24
    Maybe I should feature-request that backups get sent off-site automatically with user credentials/location...shouldn't be hard to implement...
  10. cobaltit
    Mar 22, 2012
    1,774
    280
    Offsite backups is already available with v15 SP5 and later with Google Drive integration
  11. Bret Gordon
    Jun 16, 2017
    24
    cool, ty. i'll implement :)
