install softphone (phone for windows) offline
jose1
I need install softphone 3CX only.
Does any possibility exists for an offline installation without any Internet connection?
Best regards
Hello @jose1
You could in theory install the 3CX client offline if you have the dependencies of the client already installed on the PC. If the client does not detect the correct Redistributables version then it will try to download them online.
Hi YiannisH.
Thank you for your reply
You know like to install the dependences?
Best regards.
Get 3CX - Absolutely Free!
3CX
