Install version and no sound
Discussion in '3CX Phone System - General' started by stef69, Jul 3, 2007.
  1. stef69
    Jul 1, 2007
    7
    I'm a newbie on this forum i have installed 3CX for 1 week i have 2 problems
    - I downnload the v3.1.2295 and i get the v3.0.2328.0 installed. its normal ?
    - I confirgured 1 extension and SIP gateway (all green no bad log) routeur OK for NAT. my problem is:
    I can pass calls, the phone is ringing but when the other side pick up they can here me but i cant ear them ? ( X-lite client)
    does someone have this problem or have a clue to solve my problem ?
  2. DaKhalli
    DaKhalli New Member
    Jun 2, 2007
    122
    Try adding a public STUN server adress to your x-lite softphone,
    also check my firewall faq to see if you missed any ports, you needto configure ports on both routers (e.g. home and office)
    http://www.3cx.com/forums/viewtopic.php?t=1697
  3. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    Sir is the external phone configured as "bind to media server" and "extension is external" ?
