Install with two other number...
Discussion in '3CX Phone System - General' started by Mischa, Nov 16, 2016.
  1. Mischa
    Nov 15, 2016
    5
    I have question ... and problem with startup config.
    Our company have 2 others numbers: 1234567, 567890 ... how to setup first install and how setup, that incomming number is: 1234567
    and when calling out, then outcomming number is 567890?
  2. mortenjorge
    Apr 1, 2015
    59
    12
    Hi Mischa,
    First Create Create DID with the Incoming number 1234567 to go to the Call queue (example).
    Then you several options.
    GO the the SIP-Trunk/Gateway and change Outbound Caller ID to 567890.
    if you want Extension 200 to dial out with 1234567 go to the Extension 200>General and change to "Outbound Caller ID".
    Please notice that this requires either CLIP_SA or CLIP if you do not has the specific number on your SIP-Trunk/gateway.
  3. Mischa
    Nov 15, 2016
    5
    thank you i try it.
