Installation crashes under Vista RC2 (build 5744)
Discussion in '3CX Phone System - General' started by Anonymous, Nov 9, 2006.
  1. Anonymous
    Anonymous Guest
    I've just downloaded the latest version and the installation crashes under Vista RC2.
    Specifically, it seems that it fails to install the database. Apache does get installed and I can access the administration UI, which shows the following error:
    Can't connect to the database server
    SQLSTATE[08006] [7] FATAL: password authentication failed for user "xxxxxx"
    #0 C:\Program Files\3CX\PhoneSystem\Data\Http\functions\CallContext.php(35): PDO->__construct('pgsql:dbname=ph...', 'xxxxxx', 'xxxxxx')
    #1 C:\Program Files\3CX\PhoneSystem\Data\Http\functions\fExtension.php(30): CallContext->getConnection()
    #2 C:\Program Files\3CX\PhoneSystem\Data\Http\functions\fObject.php(19): fExtension->getData()
    #3 C:\Program Files\3CX\PhoneSystem\Data\Http\index.php(7): fObject->getManager()
    #4 {main}
    Yours,
    Morten
  2. vadim
    Aug 17, 2006
    9
    It means if some data is in inconsistent state. Look PM for details.
  3. pip-k
    Nov 1, 2006
    8
    Hi Morten
    It also gives me the same result with XP Home.
    Using eventvwr it gives me this
    The following information is part of the event: FATAL: no pg_hba.conf entry for host "::1", user "phonesystem", database "phonesystem", SSL off
    It means nothing to me, but might to someone. If you fathom out what's wrong I would appreciate some feedback.
    Cheers
    Philip
