Installation error. 3CX cannot be installed on windows
Discussion in '3CX Phone System - General' started by LiscardGP, Mar 12, 2015.
  1. LiscardGP
    Sep 29, 2011
    54
    I have a clean build windows 7 professional PC x86 on which I am attempting to install 3CX version 125. When attempting installation it fails immediately with a message which starts "3CX cannot be installed on windows" and then lists the various versions of windows. I have been using 3CX for a few years and never had an error such as this. Can any one help. I attach the log produced when the installation fails.
    Thanks in advance for any replies.
    FURTHER NOTE. I THINK I HAVE SOLVED THE PROBLEM. Is it the case that 3CX 125 will only install on Windows 7 Professional x64?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,313
    249
    You hit the nail on the head.
    http://www.3cx.com/docs/installing-3cx/
  3. LiscardGP
    Sep 29, 2011
    54
    Thanks for the reply.
    When I realised the problem I though I should leave the post active in case others make the same mistake.
    Maybe I should have realised sooner what was happening but I just checked the Administrator manual which does not alert readers to the fact there are now different versions of 3CX for different operating systems. I think the manual could be improved in this respect.
  4. complex1
    complex1 Active Member
    Jan 25, 2010
    788
    45
    Mmmm, did you read the 3CX Phone System version 12.5 Administrator Manual?
