Installation error.
Discussion in '3CX Phone System - General' started by SteelWolf, Aug 11, 2013.
  1. SteelWolf
    Aug 11, 2013
    I get to about 98% installed and then it says script error and rolls back the install. I just did a fresh install of XP Pro and updated it back up to SP3 and did all the smaller updates. I had to manually install "Installer 4.5" software for it.
    MSI (c) (14:C8) [19:24:11:031]: Product: 3CX PhoneSystem -- 3CX PhoneSystem cannot be installed on the following Windows versions: Windows NT 4.0, Windows 2000, Windows XP x86,
    And this is why apparently. XP x86 version. Grr This means either taking a good PC to the field for testing a mesh network. Or finding a simple PBX system that can run on windows/mac os. http://www.hsmm-mesh.org/ I', a Amateur radio operator that is helping to setup a Mesh network and i had hopped to take a working PBX to the field in 2 weeks on a Dell D410 Laptop. 1g ram.
    J.
    === Verbose logging started: 8/10/2013 19:24:04 Build type: SHIP UNICODE 4.05.6001.00 Calling process: C:\WINDOWS\system32\msiexec.exe ===
    MSI (c) (14:C8) [19:24:04:531]: Resetting cached policy values
    MSI (c) (14:C8) [19:24:04:531]: Machine policy value 'Debug' is 0
    MSI (c) (14:C8) [19:24:04:531]: ******* RunEngine:
    ******* Product: C:\Documents and Settings\All Users\Application Data\3CX\Installer Cache\3CX PhoneSystem 12.0.31763.282\install\3CXPhoneSystem12_12.0.31763.282.msi
    ******* Action:
    ******* CommandLine: **********
    MSI (c) (14:C8) [19:24:04:531]: Machine policy value 'DisableUserInstalls' is 0
    MSI (c) (14:C8) [19:24:04:531]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'C:\Documents and Settings\All Users\Application Data\3CX\Installer Cache\3CX PhoneSystem 12.0.31763.282\install\3CXPhoneSystem12_12.0.31763.282.msi' against software restriction policy
    MSI (c) (14:C8) [19:24:04:531]: SOFTWARE RESTRICTION POLICY: C:\Documents and Settings\All Users\Application Data\3CX\Installer Cache\3CX PhoneSystem 12.0.31763.282\install\3CXPhoneSystem12_12.0.31763.282.msi has a digital signature
    MSI (c) (14:C8) [19:24:04:656]: SOFTWARE RESTRICTION POLICY: C:\Documents and Settings\All Users\Application Data\3CX\Installer Cache\3CX PhoneSystem 12.0.31763.282\install\3CXPhoneSystem12_12.0.31763.282.msi is permitted to run at the 'unrestricted' authorization level.
    MSI (c) (14:C8) [19:24:04:671]: Cloaking enabled.
    MSI (c) (14:C8) [19:24:04:671]: Attempting to enable all disabled privileges before calling Install on Server
    MSI (c) (14:C8) [19:24:04:671]: End dialog not enabled
    MSI (c) (14:C8) [19:24:04:671]: Original package ==> C:\Documents and Settings\All Users\Application Data\3CX\Installer Cache\3CX PhoneSystem 12.0.31763.282\install\3CXPhoneSystem12_12.0.31763.282.msi
    MSI (c) (14:C8) [19:24:04:671]: Package we're running from ==> C:\DOCUME~1OCALS~1\Temp\146ed5.msi
    MSI (c) (14:C8) [19:24:04:671]: APPCOMPAT: looking for appcompat database entry with ProductCode '{761BD6E5-D43F-4470-8836-8A4CF4FCE5CD}'.
    MSI (c) (14:C8) [19:24:04:671]: APPCOMPAT: no matching ProductCode found in database.
    MSI (c) (14:C8) [19:24:04:671]: MSCOREE not loaded loading copy from system32
    MSI (c) (14:C8) [19:24:04:671]: Machine policy value 'TransformsSecure' is 0
    MSI (c) (14:C8) [19:24:04:671]: User policy value 'TransformsAtSource' is 0
    MSI (c) (14:C8) [19:24:04:671]: Note: 1: 2205 2: 3: File
    MSI (c) (14:C8) [19:24:04:671]: Note: 1: 2205 2: 3: MsiFileHash
    MSI (c) (14:C8) [19:24:04:671]: Note: 1: 2205 2: 3: Component
    MSI (c) (14:C8) [19:24:04:671]: Machine policy value 'DisablePatch' is 0
    MSI (c) (14:C8) [19:24:04:671]: Machine policy value 'AllowLockdownPatch' is 0
    MSI (c) (14:C8) [19:24:04:671]: Machine policy value 'DisableLUAPatching' is 0
    MSI (c) (14:C8) [19:24:04:671]: Machine policy value 'DisableFlyWeightPatching' is 0
    MSI (c) (14:C8) [19:24:04:671]: Note: 1: 2205 2: 3: Feature
    MSI (c) (14:C8) [19:24:04:671]: Looking for file transform: C:\Documents and Settings\All Users\Application Data\3CX\Installer Cache\3CX PhoneSystem 12.0.31763.282\install\3CXPhoneSystem12_12.0.31763.282.mst
    MSI (c) (14:C8) [19:24:04:687]: Original transform ==> C:\Documents and Settings\All Users\Application Data\3CX\Installer Cache\3CX PhoneSystem 12.0.31763.282\install\3CXPhoneSystem12_12.0.31763.282.mst
    MSI (c) (14:C8) [19:24:04:687]: Transform we're running from ==> C:\DOCUME~1LOCALS~1\Temp\146ed6.mst
    MSI (c) (14:C8) [19:24:04:687]: SOFTWARE RESTRICTION POLICY: Verifying transform --> 'C:\Documents and Settings\All Users\Application Data\3CX\Installer Cache\3CX PhoneSystem 12.0.31763.282\install\3CXPhoneSystem12_12.0.31763.282.mst' against software restriction policy
    MSI (c) (14:C8) [19:24:04:687]: SOFTWARE RESTRICTION POLICY: C:\Documents and Settings\All Users\Application Data\3CX\Installer Cache\3CX PhoneSystem 12.0.31763.282\install\3CXPhoneSystem12_12.0.31763.282.mst has a digital signature
    MSI (c) (14:C8) [19:24:04:734]: SOFTWARE RESTRICTION POLICY: C:\Documents and Settings\All Users\Application Data\3CX\Installer Cache\3CX PhoneSystem 12.0.31763.282\install\3CXPhoneSystem12_12.0.31763.282.mst is permitted to run at the 'unrestricted' authorization level.
    MSI (c) (14:C8) [19:24:04:734]: Note: 1: 2205 2: 3: Media
    MSI (c) (14:C8) [19:24:04:734]: Note: 1: 2205 2: 3: File
    MSI (c) (14:C8) [19:24:04:734]: Note: 1: 2205 2: 3: Patch
    MSI (c) (14:C8) [19:24:04:734]: Note: 1: 2205 2: 3: PatchPackage
    MSI (c) (14:C8) [19:24:05:984]: Note: 1: 2262 2: PatchPackage 3: -2147287038
    MSI (c) (14:C8) [19:24:05:984]: Note: 1: 2262 2: Patch 3: -2147287038
    MSI (c) (14:C8) [19:24:05:984]: TRANSFORM: 'PatchPackage' table is missing or empty. No pre-transform fixup necessary.
    MSI (c) (14:C8) [19:24:05:984]: TRANSFORM: Applying regular transform to database.
    MSI (c) (14:C8) [19:24:06:000]: Note: 1: 2262 2: #_PatchCache 3: -2147287038
    MSI (c) (14:C8) [19:24:06:000]: Note: 1: 2262 2: #_BaselineData 3: -2147287038
    MSI (c) (14:C8) [19:24:06:000]: Note: 1: 2262 2: #_BaselineFile 3: -2147287038
    MSI (c) (14:C8) [19:24:06:000]: Note: 1: 2262 2: #_BaselineCost 3: -2147287038
    MSI (c) (14:C8) [19:24:06:000]: Note: 1: 2262 2: _MsiPatchTransformView 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: PatchPackage 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: Patch 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: Billboard 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: MsiDriverPackages 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: Extension 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: AppId 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: BBControl 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: Class 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: ProgId 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: ComboBox 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: CompLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: Complus 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: DrLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: DuplicateFile 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: MIME 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: Font 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: IniLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: IsolatedComponent 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: ListBox 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: ListView 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: LockPermissions 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: MoveFile 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: MsiEmbeddedChainer 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: MsiPackageCertificate 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: MsiPatchCertificate 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: MsiServiceConfig 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: MsiServiceConfigFailureActions 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: ODBCAttribute 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: ODBCDriver 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: ODBCDataSource 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: ODBCSourceAttribute 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: ODBCTranslator 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: PublishComponent 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: RemoveIniFile 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: RemoveRegistry 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: ReserveCost 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: SelfReg 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: Signature 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: TypeLib 3: -2147287038
    MSI (c) (14:C8) [19:24:06:015]: Note: 1: 2262 2: Verb 3: -2147287038
    [snip]
    MSI (c) (14:C8) [19:24:06:062]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\SteelWolf-KE7RIP\Desktop
    MSI (c) (14:C8) [19:24:06:062]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Templates
    MSI (c) (14:C8) [19:24:06:062]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\Fonts
    MSI (c) (14:C8) [19:24:06:062]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
    MSI (c) (14:C8) [19:24:06:062]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
    MSI (c) (14:C8) [19:24:06:062]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
    MSI (c) (14:C8) [19:24:06:062]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'SteelWolf-KE7RIP'.
    MSI (c) (14:C8) [19:24:06:062]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'PORTNEUF VALLEY A.R.E.S.'.
    MSI (c) (14:C8) [19:24:06:062]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\DOCUME~1\STEELW~1\LOCALS~1\Temp\146ed5.msi'.
    MSI (c) (14:C8) [19:24:06:062]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'C:\Documents and Settings\All Users\Application Data\3CX\Installer Cache\3CX PhoneSystem 12.0.31763.282\install\3CXPhoneSystem12_12.0.31763.282.msi'.
    MSI (c) (14:C8) [19:24:06:062]: Machine policy value 'MsiDisableEmbeddedUI' is 0
    MSI (c) (14:C8) [19:24:06:062]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'C:\Documents and Settings\All Users\Application Data\3CX\Installer Cache\3CX PhoneSystem 12.0.31763.282\install\'.
    MSI (c) (14:C8) [19:24:06:062]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'C:\Documents and Settings\All Users\Application Data\3CX\Installer Cache\3CX PhoneSystem 12.0.31763.282\install\'.
    MSI (c) (14:8C) [19:24:06:062]: PROPERTY CHANGE: Adding VersionHandler property. Its value is '4.05'.
    MSI (c) (14:8C) [19:24:06:062]: Note: 1: 2262 2: ControlEvent 3: -2147287038
    MSI (c) (14:8C) [19:24:06:078]: Transforming table ControlEvent.
    MSI (c) (14:8C) [19:24:06:078]: Note: 1: 2262 2: ControlCondition 3: -2147287038
    MSI (c) (14:8C) [19:24:06:093]: Transforming table ControlCondition.
    MSI (c) (14:8C) [19:24:06:093]: Note: 1: 2262 2: EventMapping 3: -2147287038
    MSI (c) (14:8C) [19:24:06:109]: Transforming table EventMapping.
    MSI (c) (14:8C) [19:24:06:109]: Note: 1: 2262 2: UIText 3: -2147287038
    MSI (c) (14:8C) [19:24:06:125]: Transforming table UIText.
    MSI (c) (14:8C) [19:24:06:125]: Note: 1: 2262 2: TextStyle 3: -2147287038
    MSI (c) (14:8C) [19:24:06:140]: Transforming table TextStyle.
    MSI (c) (14:8C) [19:24:06:140]: Note: 1: 2262 2: Dialog 3: -2147287038
    MSI (c) (14:8C) [19:24:06:156]: Transforming table Dialog.
    MSI (c) (14:8C) [19:24:06:156]: Note: 1: 2262 2: Dialog 3: -2147287038
    MSI (c) (14:8C) [19:24:06:171]: Transforming table Dialog.
    === Logging started: 8/10/2013 19:24:06 ===
    MSI (c) (14:C8) [19:24:06:218]: Note: 1: 2262 2: PatchPackage 3: -2147287038
    MSI (c) (14:C8) [19:24:06:218]: Note: 1: 2262 2: Media 3: -2147287038
    MSI (c) (14:C8) [19:24:06:234]: Transforming table Media.
    MSI (c) (14:C8) [19:24:06:234]: Machine policy value 'DisableRollback' is 0
    MSI (c) (14:C8) [19:24:06:234]: User policy value 'DisableRollback' is 0
    MSI (c) (14:C8) [19:24:06:234]: PROPERTY CHANGE: Adding UILevel property. Its value is '5'.
    MSI (c) (14:C8) [19:24:06:234]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
    MSI (c) (14:C8) [19:24:06:234]: Doing action: INSTALL
    MSI (c) (14:C8) [19:24:06:234]: Note: 1: 2262 2: ActionText 3: -2147287038
    MSI (c) (14:C8) [19:24:06:250]: Transforming table ActionText.
    Action 19:24:06: INSTALL.
    Action start 19:24:06: INSTALL.
    MSI (c) (14:C8) [19:24:06:250]: Note: 1: 2262 2: InstallUISequence 3: -2147287038
    MSI (c) (14:C8) [19:24:06:265]: Transforming table InstallUISequence.
    MSI (c) (14:C8) [19:24:06:265]: UI Sequence table 'InstallUISequence' is present and populated.
    MSI (c) (14:C8) [19:24:06:265]: Running UISequence
    MSI (c) (14:C8) [19:24:06:265]: PROPERTY CHANGE: Adding EXECUTEACTION property. Its value is 'INSTALL'.
    MSI (c) (14:C8) [19:24:06:265]: Doing action: SystemFolder.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E
    Action 19:24:06: SystemFolder.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E.
    Action start 19:24:06: SystemFolder.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E.
    MSI (c) (14:C8) [19:24:06:265]: Note: 1: 2262 2: CustomAction 3: -2147287038
    MSI (c) (14:C8) [19:24:06:343]: Transforming table CustomAction.
    MSI (c) (14:C8) [19:24:06:343]: PROPERTY CHANGE: Adding SystemFolder.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\WINDOWS\system32\'.
    Action ended 19:24:06: SystemFolder.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E. Return value 1.
    MSI (c) (14:C8) [19:24:06:343]: Doing action: WindowsFolder.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E
    Action 19:24:06: WindowsFolder.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E.
    Action start 19:24:06: WindowsFolder.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E.
    MSI (c) (14:C8) [19:24:06:343]: Note: 1: 2262 2: CustomAction 3: -2147287038
    MSI (c) (14:C8) [19:24:06:359]: Transforming table CustomAction.
    MSI (c) (14:C8) [19:24:06:359]: PROPERTY CHANGE: Adding WindowsFolder.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E property. Its value is 'C:\WINDOWS\'.
    Action ended 19:24:06: WindowsFolder.844EFBA7_1C24_93B2_FF1F_C8B3B9A1E18E. Return value 1.
    MSI (c) (14:C8) [19:24:06:359]: Doing action: AI_SET_INSTALL
    Action 19:24:06: AI_SET_INSTALL.
    Action start 19:24:06: AI_SET_INSTALL.
    MSI (c) (14:C8) [19:24:06:359]: Note: 1: 2262 2: CustomAction 3: -2147287038
    MSI (c) (14:C8) [19:24:06:375]: Transforming table CustomAction.
    MSI (c) (14:C8) [19:24:06:375]: PROPERTY CHANGE: Adding AI_INSTALL property. Its value is '1'.
    Action ended 19:24:06: AI_SET_INSTALL. Return value 1.
    MSI (c) (14:C8) [19:24:06:375]: Skipping action: AI_SET_MAINT (condition is false)
    MSI (c) (14:C8) [19:24:06:375]: Skipping action: AI_SET_RESUME (condition is false)
    MSI (c) (14:C8) [19:24:06:375]: Skipping action: AI_SET_PATCH (condition is false)
    MSI (c) (14:C8) [19:24:06:375]: Skipping action: AI_CORRECT_INSTALL (condition is false)
    MSI (c) (14:C8) [19:24:06:375]: Doing action: AI_ResolveLocalizedCredentials
    Action 19:24:06: AI_ResolveLocalizedCredentials.
    Action start 19:24:06: AI_ResolveLocalizedCredentials.
    MSI (c) (14:C8) [19:24:06:375]: Note: 1: 2262 2: CustomAction 3: -2147287038
    MSI (c) (14:C8) [19:24:06:390]: Transforming table CustomAction.
    MSI (c) (14:C8) [19:24:06:390]: Note: 1: 2262 2: Binary 3: -2147287038
    MSI (c) (14:C8) [19:24:06:406]: Transforming table Binary.
    MSI (c) (14:38) [19:24:06:406]: Invoking remote custom action. DLL: C:\DOCUME~1\STEELW~1\LOCALS~1\Temp\MSI52.tmp, Entrypoint: GetLocalizedCredentials
    MSI (c) (14:B4) [19:24:06:421]: Cloaking enabled.
    MSI (c) (14:B4) [19:24:06:421]: Attempting to enable all disabled privileges before calling Install on Server
    MSI (c) (14:B4) [19:24:06:421]: Connected to service for CA interface.
    Getting localized credentials and storing them in properties...
    LookupUserGroupFromRid: 500 257
    NetUserModalsGet will use empty target computer name.
    subAuthorityCount: 4
    Initialized Sid successfuly
    Copying subauthorities...
    Copying subauthorities done.
    Appending Rid to new Sid...
    Appending Rid to new Sid done.
    resolving for SID: S-1-5-21-796845957-1645522239-725345543-500
    LookupAccountSidW returned 1
    Freeing buffers..
    Buffers freed.
    MSI (c) (14!B8) [19:24:06:500]: PROPERTY CHANGE: Adding USR_ADMINISTRATOR property. Its value is 'Administrator'.
    LookupUserGroupFromRid: 501 257
    resolving for SID: S-1-5-21-796845957-1645522239-725345543-501
    Freeing buffers..
    Buffers freed.
    MSI (c) (14!B8) [19:24:06:500]: PROPERTY CHANGE: Adding USR_GUEST property. Its value is 'Guest'.
    LookupUserGroupFromRid: 502 257
    resolving for SID: S-1-5-21-796845957-1645522239-725345543-502
    LookupAccountSidW returned 0
    Freeing buffers..
    Buffers freed.
    LookupUserGroupFromRid failed
    LookupUserGroupFromRid: 513 257
    resolving for SID: S-1-5-21-796845957-1645522239-725345543-513
    Freeing buffers..
    Buffers freed.
    MSI (c) (14!B8) [19:24:06:515]: PROPERTY CHANGE: Adding GRP_DOMAIN_USERS property. Its value is 'None'.
    LookupUserGroupFromRid: 515 257
    resolving for SID: S-1-5-21-796845957-1645522239-725345543-515
    Freeing buffers..
    Buffers freed.
    LookupUserGroupFromRid: 516 257
    resolving for SID: S-1-5-21-796845957-1645522239-725345543-516
    Freeing buffers..
    Buffers freed.
    LookupUserGroupFromRidSDDL: WD None 257
    ConvertStringSidToSid successful!
    Freeing sid..
    Freeing sid done.
    MSI (c) (14!B8) [19:24:06:531]: PROPERTY CHANGE: Adding GRP_EVERYONE property. Its value is 'Everyone'.
    LookupUserGroupFromRidSDDL: NS Everyone 257
    Freeing sid..
    Freeing sid done.
    MSI (c) (14!B8) [19:24:06:531]: PROPERTY CHANGE: Adding USR_NETWORK_SERVICE property. Its value is 'NETWORK SERVICE'.
    LookupUserGroupFromRidSDDL: AO NETWORK SERVICE 257
    Freeing sid..
    Freeing sid done.
    LookupUserGroupFromRidSDDL failed
    LookupUserGroupFromRidSDDL: SO NETWORK SERVICE 257
    Freeing sid..
    Freeing sid done.
    LookupUserGroupFromRidSDDL: PO NETWORK SERVICE 257
    Freeing sid..
    Freeing sid done.
    LookupUserGroupFromRidSDDL: BO NETWORK SERVICE 257
    Freeing sid..
    Freeing sid done.
    MSI (c) (14!B8) [19:24:06:531]: PROPERTY CHANGE: Adding GRP_BACKUP_OPS property. Its value is 'Backup Operators'.
    LookupAliasFromRid: 544 257
    Target empty, so account name translation begins on the local system.
    MSI (c) (14!B8) [19:24:06:531]: PROPERTY CHANGE: Adding GRP_ADMINISTRATORS property. Its value is 'Administrators'.
    LookupAliasFromRid: 545 257
    MSI (c) (14!B8) [19:24:06:531]: PROPERTY CHANGE: Adding GRP_USERS property. Its value is 'Users'.
    LookupAliasFromRid: 546 257
    MSI (c) (14!B8) [19:24:06:531]: PROPERTY CHANGE: Adding GRP_GUESTS property. Its value is 'Guests'.
    LookupAliasFromRid: 547 257
    MSI (c) (14!B8) [19:24:06:546]: PROPERTY CHANGE: Adding GRP_POWER_USERS property. Its value is 'Power Users'.
    LookupAliasFromRid: 552 257
    MSI (c) (14!B8) [19:24:06:546]: PROPERTY CHANGE: Adding GRP_REPLICATOR property. Its value is 'Replicator'.
    LookupAliasFromRid: 553 257
    LookupAliasFromRid failed
    LookupAliasFromRid: 554 257
    LookupAliasFromRid: 555 257
    MSI (c) (14!B8) [19:24:06:546]: PROPERTY CHANGE: Adding GRP_REMOTE_DESKTOP_USERS property. Its value is 'Remote Desktop Users'.
    LookupAliasFromRid: 556 257
    MSI (c) (14!B8) [19:24:06:546]: PROPERTY CHANGE: Adding GRP_NETWORK_CONFIGURATION_OPS property. Its value is 'Network Configuration Operators'.
    LookupAliasFromRid: 557 257
    LookupAliasFromRid: 558 257
    LookupAliasFromRid: 559 257
    Action ended 19:24:06: AI_ResolveLocalizedCredentials. Return value 1.
    MSI (c) (14:C8) [19:24:06:546]: Doing action: AI_ResolveKnownFolders
    Action 19:24:06: AI_ResolveKnownFolders.
    Action start 19:24:06: AI_ResolveKnownFolders.
    MSI (c) (14:C8) [19:24:06:546]: Note: 1: 2262 2: CustomAction 3: -2147287038
    MSI (c) (14:C8) [19:24:06:562]: Transforming table CustomAction.
    MSI (c) (14:C8) [19:24:06:562]: Note: 1: 2262 2: Binary 3: -2147287038
    MSI (c) (14:C8) [19:24:06:578]: Transforming table Binary.
    MSI (c) (14:3C) [19:24:06:578]: Invoking remote custom action. DLL: C:\DOCUME~1\STEELW~1\LOCALS~1\Temp\MSI53.tmp, Entrypoint: AI_ResolveKnownFolders
    MSI (c) (14!64) [19:24:06:625]: PROPERTY CHANGE: Adding PublicDocumentsFolder property. Its value is 'C:\Documents and Settings\All Users\Documents\'.
    Action ended 19:24:06: AI_ResolveKnownFolders. Return value 1.
    MSI (c) (14:C8) [19:24:06:625]: Doing action: PrepareDlg
    Action 19:24:06: PrepareDlg.
    Action start 19:24:06: PrepareDlg.
    MSI (c) (14:C8) [19:24:06:625]: Note: 1: 2262 2: CustomAction 3: -2147287038
    MSI (c) (14:C8) [19:24:06:625]: Transforming table CustomAction.
    MSI (c) (14:8C) [19:24:06:640]: Note: 1: 2262 2: Error 3: -2147287038
    MSI (c) (14:8C) [19:24:06:640]: Transforming table Error.
    Info 2898. For DlgFont8 textstyle, the system created a 'Tahoma' font, in 0 character set.
    MSI (c) (14:8C) [19:24:06:656]: Note: 1: 2262 2: Error 3: -2147287038
    MSI (c) (14:8C) [19:24:06:656]: Transforming table Error.
    Info 2826. Control BottomLine on dialog PrepareDlg extends beyond the boundaries of the dialog to the right by 3 pixels.
    MSI (c) (14:8C) [19:24:06:671]: Note: 1: 2262 2: Binary 3: -2147287038
    MSI (c) (14:8C) [19:24:06:671]: Transforming table Binary.
    MSI (c) (14:8C) [19:24:06:687]: Note: 1: 2262 2: Error 3: -2147287038
    MSI (c) (14:8C) [19:24:06:703]: Transforming table Error.
    Info 2898. For VerdanaBold13 textstyle, the system created a 'Verdana' font, in 0 character set.
    Action 19:24:06: PrepareDlg. Dialog created
    Action ended 19:24:06: PrepareDlg. Return value 1.
    MSI (c) (14:C8) [19:24:06:750]: Doing action: ProvSubDirGenerateCode
    Action 19:24:06: ProvSubDirGenerateCode.
    Action start 19:24:06: ProvSubDirGenerateCode.
    MSI (c) (14:C8) [19:24:06:750]: Note: 1: 2262 2: CustomAction 3: -2147287038
    MSI (c) (14:C8) [19:24:06:765]: Transforming table CustomAction.
    MSI (c) (14:C8) [19:24:06:765]: Note: 1: 2262 2: Binary 3: -2147287038
    MSI (c) (14:C8) [19:24:06:781]: Transforming table Binary.
    MSI (c) (14!C8) [19:24:06:828]: PROPERTY CHANGE: Modifying PROVSUBDIR property. Its current value is '3CX'. Its new value: '07568l5zqk'.
    Action ended 19:24:06: ProvSubDirGenerateCode. Return value 0.
    MSI (c) (14:C8) [19:24:06:828]: Doing action: AI_BACKUP_AI_SETUPEXEPATH
    Action 19:24:06: AI_BACKUP_AI_SETUPEXEPATH.
    Action start 19:24:06: AI_BACKUP_AI_SETUPEXEPATH.
    MSI (c) (14:C8) [19:24:06:828]: Note: 1: 2262 2: CustomAction 3: -2147287038
    MSI (c) (14:C8) [19:24:06:843]: Transforming table CustomAction.
    MSI (c) (14:C8) [19:24:06:843]: PROPERTY CHANGE: Adding AI_SETUPEXEPATH_ORIGINAL property. Its value is 'C:\Documents and Settings\SteelWolf-KE7RIP\My Documents\Downloads\3CXPhoneSystem12.exe'.
    Action ended 19:24:06: AI_BACKUP_AI_SETUPEXEPATH. Return value 1.
    MSI (c) (14:C8) [19:24:06:843]: Doing action: AppSearch
    Action 19:24:06: AppSearch. Searching for installed applications
    Action start 19:24:06: AppSearch.
    MSI (c) (14:C8) [19:24:06:843]: Note: 1: 2262 2: AppSearch 3: -2147287038
    MSI (c) (14:C8) [19:24:06:859]: Transforming table AppSearch.
    AppSearch: Property: IISINSTALLED, Signature: AppSearchSign_10
    MSI (c) (14:C8) [19:24:06:859]: Note: 1: 2262 2: Signature 3: -2147287038
    MSI (c) (14:C8) [19:24:06:859]: Note: 1: 2262 2: CompLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:06:859]: Note: 1: 2262 2: RegLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:06:875]: Transforming table RegLocator.
    MSI (c) (14:C8) [19:24:06:875]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\InetStp 3: 2
    MSI (c) (14:C8) [19:24:06:875]: Note: 1: 2262 2: IniLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:06:875]: Note: 1: 2262 2: DrLocator 3: -2147287038
    AppSearch: Property: WEBSERVER, Signature: AppSearchSign_13
    MSI (c) (14:C8) [19:24:06:875]: Note: 1: 2262 2: Signature 3: -2147287038
    MSI (c) (14:C8) [19:24:06:875]: Note: 1: 2262 2: CompLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:06:875]: Note: 1: 2262 2: RegLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:06:890]: Transforming table RegLocator.
    MSI (c) (14:C8) [19:24:06:890]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\SOFTWARE\3CX\PhoneSystem 3: 2
    MSI (c) (14:C8) [19:24:06:890]: Note: 1: 2262 2: IniLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:06:890]: Note: 1: 2262 2: DrLocator 3: -2147287038
    AppSearch: Property: UAC_STATUS, Signature: AppSearchSign_14
    MSI (c) (14:C8) [19:24:06:890]: Note: 1: 2262 2: Signature 3: -2147287038
    MSI (c) (14:C8) [19:24:06:890]: Note: 1: 2262 2: CompLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:06:890]: Note: 1: 2262 2: RegLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:06:906]: Transforming table RegLocator.
    MSI (c) (14:C8) [19:24:06:906]: Note: 1: 2262 2: IniLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:06:906]: Note: 1: 2262 2: DrLocator 3: -2147287038
    AppSearch: Property: SERVICE_INSTALLED_FAXSERVER, Signature: AppSearchSign_5
    MSI (c) (14:C8) [19:24:06:906]: Note: 1: 2262 2: Signature 3: -2147287038
    MSI (c) (14:C8) [19:24:06:906]: Note: 1: 2262 2: CompLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:06:906]: Note: 1: 2262 2: RegLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:06:921]: Transforming table RegLocator.
    MSI (c) (14:C8) [19:24:06:921]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\3CXFAXSrv 3: 2
    MSI (c) (14:C8) [19:24:06:921]: Note: 1: 2262 2: IniLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:06:921]: Note: 1: 2262 2: DrLocator 3: -2147287038
    AppSearch: Property: SERVICE_INSTALLED_PARKORBIT, Signature: AppSearchSign_8
    MSI (c) (14:C8) [19:24:06:921]: Note: 1: 2262 2: Signature 3: -2147287038
    MSI (c) (14:C8) [19:24:06:921]: Note: 1: 2262 2: CompLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:06:921]: Note: 1: 2262 2: RegLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:06:937]: Transforming table RegLocator.
    MSI (c) (14:C8) [19:24:06:937]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\3CXParkOrbit 3: 2
    MSI (c) (14:C8) [19:24:06:937]: Note: 1: 2262 2: IniLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:06:937]: Note: 1: 2262 2: DrLocator 3: -2147287038
    AppSearch: Property: SERVICE_INSTALLED_MEDIASERVER, Signature: AppSearchSign_7
    MSI (c) (14:C8) [19:24:06:937]: Note: 1: 2262 2: Signature 3: -2147287038
    MSI (c) (14:C8) [19:24:06:937]: Note: 1: 2262 2: CompLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:06:937]: Note: 1: 2262 2: RegLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:06:953]: Transforming table RegLocator.
    MSI (c) (14:C8) [19:24:06:953]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\3CX PhoneSystem Media Server 3: 2
    MSI (c) (14:C8) [19:24:06:953]: Note: 1: 2262 2: IniLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:06:953]: Note: 1: 2262 2: DrLocator 3: -2147287038
    AppSearch: Property: SERVICE_INSTALLED_IVR, Signature: AppSearchSign_6
    MSI (c) (14:C8) [19:24:06:953]: Note: 1: 2262 2: Signature 3: -2147287038
    MSI (c) (14:C8) [19:24:06:953]: Note: 1: 2262 2: CompLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:06:953]: Note: 1: 2262 2: RegLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:06:968]: Transforming table RegLocator.
    MSI (c) (14:C8) [19:24:06:968]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\3CXIvr 3: 2
    MSI (c) (14:C8) [19:24:06:968]: Note: 1: 2262 2: IniLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:06:968]: Note: 1: 2262 2: DrLocator 3: -2147287038
    AppSearch: Property: SERVICE_INSTALLED_CONFERENCEROOM, Signature: AppSearchSign_3
    MSI (c) (14:C8) [19:24:06:968]: Note: 1: 2262 2: Signature 3: -2147287038
    MSI (c) (14:C8) [19:24:06:968]: Note: 1: 2262 2: CompLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:06:968]: Note: 1: 2262 2: RegLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:06:984]: Transforming table RegLocator.
    MSI (c) (14:C8) [19:24:06:984]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\3CXConferenceRoom 3: 2
    MSI (c) (14:C8) [19:24:06:984]: Note: 1: 2262 2: IniLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:06:984]: Note: 1: 2262 2: DrLocator 3: -2147287038
    AppSearch: Property: SERVICE_INSTALLED_DATABASESERVER, Signature: AppSearchSign_4
    MSI (c) (14:C8) [19:24:06:984]: Note: 1: 2262 2: Signature 3: -2147287038
    MSI (c) (14:C8) [19:24:06:984]: Note: 1: 2262 2: CompLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:06:984]: Note: 1: 2262 2: RegLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:07:000]: Transforming table RegLocator.
    MSI (c) (14:C8) [19:24:07:000]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\3CX PhoneSystem Database Server 3: 2
    MSI (c) (14:C8) [19:24:07:000]: Note: 1: 2262 2: IniLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:07:000]: Note: 1: 2262 2: DrLocator 3: -2147287038
    AppSearch: Property: SERVICE_INSTALLED_PHONESYSTEM, Signature: AppSearchSign_2
    MSI (c) (14:C8) [19:24:07:000]: Note: 1: 2262 2: Signature 3: -2147287038
    MSI (c) (14:C8) [19:24:07:000]: Note: 1: 2262 2: CompLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:07:000]: Note: 1: 2262 2: RegLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:07:015]: Transforming table RegLocator.
    MSI (c) (14:C8) [19:24:07:015]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\3CX PhoneSystem 3: 2
    MSI (c) (14:C8) [19:24:07:015]: Note: 1: 2262 2: IniLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:07:015]: Note: 1: 2262 2: DrLocator 3: -2147287038
    AppSearch: Property: SSLENABLED, Signature: AppSearchSign_11
    MSI (c) (14:C8) [19:24:07:015]: Note: 1: 2262 2: Signature 3: -2147287038
    MSI (c) (14:C8) [19:24:07:015]: Note: 1: 2262 2: CompLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:07:015]: Note: 1: 2262 2: RegLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:07:031]: Transforming table RegLocator.
    MSI (c) (14:C8) [19:24:07:031]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\SOFTWARE\3CX\PhoneSystem 3: 2
    MSI (c) (14:C8) [19:24:07:031]: Note: 1: 2262 2: IniLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:07:031]: Note: 1: 2262 2: DrLocator 3: -2147287038
    AppSearch: Property: SERVICE_INSTALLED_TUNNEL, Signature: AppSearchSign_9
    MSI (c) (14:C8) [19:24:07:031]: Note: 1: 2262 2: Signature 3: -2147287038
    MSI (c) (14:C8) [19:24:07:031]: Note: 1: 2262 2: CompLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:07:031]: Note: 1: 2262 2: RegLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:07:046]: Transforming table RegLocator.
    MSI (c) (14:C8) [19:24:07:046]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\3CXTunnel 3: 2
    MSI (c) (14:C8) [19:24:07:046]: Note: 1: 2262 2: IniLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:07:046]: Note: 1: 2262 2: DrLocator 3: -2147287038
    AppSearch: Property: DEFAULT_DSN_DIR, Signature: AppSearchSign_1
    MSI (c) (14:C8) [19:24:07:062]: Note: 1: 2262 2: Signature 3: -2147287038
    MSI (c) (14:C8) [19:24:07:062]: Note: 1: 2262 2: CompLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:07:062]: Note: 1: 2262 2: RegLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:07:062]: Transforming table RegLocator.
    MSI (c) (14:C8) [19:24:07:062]: PROPERTY CHANGE: Adding DEFAULT_DSN_DIR property. Its value is 'C:\Program Files\Common Files\ODBC\Data Sources'.
    AppSearch: Property: PBX_INSTALLED_VERSION, Signature: AppSearchSign
    MSI (c) (14:C8) [19:24:07:078]: Note: 1: 2262 2: Signature 3: -2147287038
    MSI (c) (14:C8) [19:24:07:078]: Note: 1: 2262 2: CompLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:07:078]: Note: 1: 2262 2: RegLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:07:078]: Transforming table RegLocator.
    MSI (c) (14:C8) [19:24:07:093]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\SOFTWARE\3CX\PhoneSystem 3: 2
    MSI (c) (14:C8) [19:24:07:093]: Note: 1: 2262 2: IniLocator 3: -2147287038
    MSI (c) (14:C8) [19:24:07:093]: Note: 1: 2262 2: DrLocator 3: -2147287038
    Action ended 19:24:07: AppSearch. Return value 1.
    MSI (c) (14:C8) [19:24:07:093]: Doing action: AI_RESTORE_AI_SETUPEXEPATH
    Action 19:24:07: AI_RESTORE_AI_SETUPEXEPATH.
    Action start 19:24:07: AI_RESTORE_AI_SETUPEXEPATH.
    MSI (c) (14:C8) [19:24:07:093]: Note: 1: 2262 2: CustomAction 3: -2147287038
    MSI (c) (14:C8) [19:24:07:109]: Transforming table CustomAction.
    Action ended 19:24:07: AI_RESTORE_AI_SETUPEXEPATH. Return value 1.
    MSI (c) (14:C8) [19:24:07:109]: Doing action: AI_AppSearchEx
    Action 19:24:07: AI_AppSearchEx.
    Action start 19:24:07: AI_AppSearchEx.
    MSI (c) (14:C8) [19:24:07:109]: Note: 1: 2262 2: CustomAction 3: -2147287038
    MSI (c) (14:C8) [19:24:07:125]: Transforming table CustomAction.
    MSI (c) (14:C8) [19:24:07:125]: Note: 1: 2262 2: Binary 3: -2147287038
    MSI (c) (14:C8) [19:24:07:140]: Transforming table Binary.
    MSI (c) (14:B8) [19:24:07:140]: Invoking remote custom action. DLL: C:\DOCUME~1\STEELW~1\LOCALS~1\Temp\MSI54.tmp, Entrypoint: DoAppSearchEx
    Action 19:24:07: AI_AppSearchEx. Searching for installed applications
    MSI (c) (14!C0) [19:24:07:171]: Note: 1: 2262 2: AI_AppSearchEx 3: -2147287038
    MSI (c) (14!C0) [19:24:07:187]: Transforming table AI_AppSearchEx.
    AI_AppSearchEx: Property: AI_VC_2010_SP1_X64_PREREQSEARCH_4_PROP, Signature: HKLM\SOFTWARE\Microsoft\VisualStudio\10.0\VC\VCRedist\x86\Rbld
    MSI (c) (14!C0) [19:24:07:203]: PROPERTY CHANGE: Adding AI_VC_2010_SP1_X64_PREREQSEARCH_4_PROP property. Its value is '1'.
    AI_AppSearchEx: Property: PREREQSEARCH, Signature: HKLM\SOFTWARE\Microsoft\DevDiv\VC\Servicing\9.0\RED\1033\SP
    AI_AppSearchEx: Property: AI_VC_2010_SP1_X64_PREREQSEARCH_3_PROP, Signature: HKLM\SOFTWARE\Microsoft\VisualStudio\10.0\VC\VCRedist\x86\Rbld
    AI_AppSearchEx: Property: AI_VC_2010_SP1_X64_PREREQSEARCH_1_PROP, Signature: HKLM\SOFTWARE\Microsoft\VisualStudio\10.0\VC\VCRedist\x86\Bld
    MSI (c) (14!C0) [19:24:07:218]: PROPERTY CHANGE: Adding AI_VC_2010_SP1_X64_PREREQSEARCH_1_PROP property. Its value is '1'.
    AI_AppSearchEx: Property: AI_VC_2010_SP1_X64_PREREQSEARCH_2_PROP, Signature: HKLM\SOFTWARE\Microsoft\VisualStudio\10.0\VC\VCRedist\x86\Bld
    Action 19:24:07: .
    MSI (c) (14!C0) [19:24:07:218]: Note: 1: 2262 2: AI_PreRequisite 3: -2147287038
    MSI (c) (14!C0) [19:24:07:234]: Transforming table AI_PreRequisite.
    Action ended 19:24:07: AI_AppSearchEx. Return value 1.
    MSI (c) (14:C8) [19:24:07:250]: Skipping action: PBXCheck (condition is false)
    MSI (c) (14:C8) [19:24:07:250]: Skipping action: CheckOSVerAbyss64 (condition is false)
    MSI (c) (14:C8) [19:24:07:250]: Skipping action: SetnetVersion (condition is false)
    MSI (c) (14:C8) [19:24:07:250]: Doing action: AI_DATA_SETTER
    Action 19:24:07: AI_DATA_SETTER.
    Action start 19:24:07: AI_DATA_SETTER.
    MSI (c) (14:C8) [19:24:07:250]: Note: 1: 2262 2: CustomAction 3: -2147287038
    MSI (c) (14:C8) [19:24:07:265]: Transforming table CustomAction.
    MSI (c) (14:C8) [19:24:07:265]: PROPERTY CHANGE: Adding CustomActionData property. Its value is '0.0.0.0|5060|PORT_SIP_TCP_IS_FREE'.
    Action ended 19:24:07: AI_DATA_SETTER. Return value 1.
    MSI (c) (14:C8) [19:24:07:265]: Doing action: GetPortStateSIP_TCP.dll
    Action 19:24:07: GetPortStateSIP_TCP.dll.
    Action start 19:24:07: GetPortStateSIP_TCP.dll.
    MSI (c) (14:C8) [19:24:07:265]: Note: 1: 2262 2: CustomAction 3: -2147287038
    MSI (c) (14:C8) [19:24:07:281]: Transforming table CustomAction.
    MSI (c) (14:C8) [19:24:07:281]: Note: 1: 2262 2: Binary 3: -2147287038
    MSI (c) (14:C8) [19:24:07:296]: Transforming table Binary.
    MSI (c) (14:08) [19:24:07:296]: Invoking remote custom action. DLL: C:\DOCUME~1\STEELW~1\LOCALS~1\Temp\MSI55.tmp, Entrypoint: CheckTCPPortState
    Action ended 19:24:07: GetPortStateSIP_TCP.dll. Return value 1.
    MSI (c) (14:C8) [19:24:07:343]: Doing action: AI_DATA_SETTER_1
    Action 19:24:07: AI_DATA_SETTER_1.
    Action start 19:24:07: AI_DATA_SETTER_1.
    MSI (c) (14:C8) [19:24:07:343]: Note: 1: 2262 2: CustomAction 3: -2147287038
    MSI (c) (14:C8) [19:24:07:359]: Transforming table CustomAction.
    MSI (c) (14:C8) [19:24:07:359]: PROPERTY CHANGE: Modifying CustomActionData property. Its current value is '0.0.0.0|5060|PORT_SIP_TCP_IS_FREE'. Its new value: '0.0.0.0|5060|PORT_SIP_UDP_IS_FREE'.
    Action ended 19:24:07: AI_DATA_SETTER_1. Return value 1.
    MSI (c) (14:C8) [19:24:07:359]: Doing action: GetPortStateSIP_UDP.dll
    Action 19:24:07: GetPortStateSIP_UDP.dll.
    Action start 19:24:07: GetPortStateSIP_UDP.dll.
    MSI (c) (14:C8) [19:24:07:359]: Note: 1: 2262 2: CustomAction 3: -2147287038
    MSI (c) (14:C8) [19:24:07:375]: Transforming table CustomAction.
    MSI (c) (14:C8) [19:24:07:375]: Note: 1: 2262 2: Binary 3: -2147287038
    MSI (c) (14:C8) [19:24:07:390]: Transforming table Binary.
    MSI (c) (14:A0) [19:24:07:390]: Invoking remote custom action. DLL: C:\DOCUME~1\STEELW~1\LOCALS~1\Temp\MSI56.tmp, Entrypoint: CheckUDPPortState
    Action ended 19:24:07: GetPortStateSIP_UDP.dll. Return value 1.
    MSI (c) (14:C8) [19:24:07:437]: Doing action: AI_DATA_SETTER_2
    Action 19:24:07: AI_DATA_SETTER_2.
    Action start 19:24:07: AI_DATA_SETTER_2.
    MSI (c) (14:C8) [19:24:07:437]: Note: 1: 2262 2: CustomAction 3: -2147287038
    MSI (c) (14:C8) [19:24:07:453]: Transforming table CustomAction.
    MSI (c) (14:C8) [19:24:07:453]: PROPERTY CHANGE: Modifying CustomActionData property. Its current value is '0.0.0.0|5060|PORT_SIP_UDP_IS_FREE'. Its new value: '0.0.0.0|5080|PORT_SIP_PROXY_IS_FREE'.
    Action ended 19:24:07: AI_DATA_SETTER_2. Return value 1.
    MSI (c) (14:C8) [19:24:07:453]: Doing action: GetPortStateSIP_PROXY.dll
    Action 19:24:07: GetPortStateSIP_PROXY.dll.
    Action start 19:24:07: GetPortStateSIP_PROXY.dll.
    MSI (c) (14:C8) [19:24:07:453]: Note: 1: 2262 2: CustomAction 3: -2147287038
    MSI (c) (14:C8) [19:24:07:468]: Transforming table CustomAction.
    MSI (c) (14:C8) [19:24:07:468]: Note: 1: 2262 2: Binary 3: -2147287038
    MSI (c) (14:C8) [19:24:07:484]: Transforming table Binary.
    MSI (c) (14:30) [19:24:07:500]: Invoking remote custom action. DLL: C:\DOCUME~1\STEELW~1\LOCALS~1\Temp\MSI57.tmp, Entrypoint: CheckTCPPortState
    Action ended 19:24:07: GetPortStateSIP_PROXY.dll. Return value 1.
    MSI (c) (14:C8) [19:24:07:531]: Doing action: AI_DATA_SETTER_3
    Action 19:24:07: AI_DATA_SETTER_3.
    Action start 19:24:07: AI_DATA_SETTER_3.
    MSI (c) (14:C8) [19:24:07:531]: Note: 1: 2262 2: CustomAction 3: -2147287038
    MSI (c) (14:C8) [19:24:07:546]: Transforming table CustomAction.
    MSI (c) (14:C8) [19:24:07:546]: PROPERTY CHANGE: Modifying CustomActionData property. Its current value is '0.0.0.0|5080|PORT_SIP_PROXY_IS_FREE'. Its new value: '127.0.0.1|5480|PORT_PGSQL_IS_FREE'.
    Action ended 19:24:07: AI_DATA_SETTER_3. Return value 1.
    MSI (c) (14:C8) [19:24:07:546]: Doing action: GetPortStatePGSQL.dll
    Action 19:24:07: GetPortStatePGSQL.dll.
    Action start 19:24:07: GetPortStatePGSQL.dll.
    MSI (c) (14:C8) [19:24:07:546]: Note: 1: 2262 2: CustomAction 3: -2147287038
    MSI (c) (14:C8) [19:24:07:562]: Transforming table CustomAction.
    MSI (c) (14:C8) [19:24:07:562]: Note: 1: 2262 2: Binary 3: -2147287038
    MSI (c) (14:C8) [19:24:07:578]: Transforming table Binary.
    MSI (c) (14:08) [19:24:07:593]: Invoking remote custom action. DLL: C:\DOCUME~1\STEELW~1\LOCALS~1\Temp\MSI58.tmp, Entrypoint: CheckTCPPortState
    Action ended 19:24:07: GetPortStatePGSQL.dll. Return value 1.
    MSI (c) (14:C8) [19:24:07:671]: Doing action: AI_DATA_SETTER_4
    Action 19:24:07: AI_DATA_SETTER_4.
    Action start 19:24:07: AI_DATA_SETTER_4.
    MSI (c) (14:C8) [19:24:07:671]: Note: 1: 2262 2: CustomAction 3: -2147287038
    MSI (c) (14:C8) [19:24:07:687]: Transforming table CustomAction.
    MSI (c) (14:C8) [19:24:07:687]: PROPERTY CHANGE: Modifying CustomActionData property. Its current value is '127.0.0.1|5480|PORT_PGSQL_IS_FREE'. Its new value: '0.0.0.0|5000|PORT_HTTP_IS_FREE'.
    Action ended 19:24:07: AI_DATA_SETTER_4. Return value 1.
    MSI (c) (14:C8) [19:24:07:687]: Doing action: GetPortStateHTTP.dll
    Action 19:24:07: GetPortStateHTTP.dll.
    Action start 19:24:07: GetPortStateHTTP.dll.
    MSI (c) (14:C8) [19:24:07:687]: Note: 1: 2262 2: CustomAction 3: -2147287038
    MSI (c) (14:C8) [19:24:07:703]: Transforming table CustomAction.
    MSI (c) (14:C8) [19:24:07:703]: Note: 1: 2262 2: Binary 3: -2147287038
    MSI (c) (14:C8) [19:24:07:718]: Transforming table Binary.
    MSI (c) (14:14) [19:24:07:718]: Invoking remote custom action. DLL: C:\DOCUME~1\STEELW~1\LOCALS~1\Temp\MSI59.tmp, Entrypoint: CheckTCPPortState
    Action ended 19:24:07: GetPortStateHTTP.dll. Return value 1.
    MSI (c) (14:C8) [19:24:07:843]: Doing action: AI_DATA_SETTER_30
    Action 19:24:07: AI_DATA_SETTER_30.
    Action start 19:24:07: AI_DATA_SETTER_30.
    MSI (c) (14:C8) [19:24:07:843]: Note: 1: 2262 2: CustomAction 3: -2147287038
    MSI (c) (14:C8) [19:24:07:859]: Transforming table CustomAction.
    MSI (c) (14:C8) [19:24:07:859]: PROPERTY CHANGE: Modifying CustomActionData property. Its current value is '0.0.0.0|5000|PORT_HTTP_IS_FREE'. Its new value: '127.0.0.1|5485|PORT_CONFIG_IS_FREE'.
    Action ended 19:24:07: AI_DATA_SETTER_30. Return value 1.
    MSI (c) (14:C8) [19:24:07:859]: Doing action: GetPortStateConfigSrv.dll
    Action 19:24:07: GetPortStateConfigSrv.dll.
    Action start 19:24:07: GetPortStateConfigSrv.dll.
    MSI (c) (14:C8) [19:24:07:859]: Note: 1: 2262 2: CustomAction 3: -2147287038
    MSI (c) (14:C8) [19:24:07:875]: Transforming table CustomAction.
    MSI (c) (14:C8) [19:24:07:875]: Note: 1: 2262 2: Binary 3: -2147287038
    MSI (c) (14:C8) [19:24:07:890]: Transforming table Binary.
    MSI (c) (14:1C) [19:24:07:906]: Invoking remote custom action. DLL: C:\DOCUME~1\STEELW~1\LOCALS~1\Temp\MSI5A.tmp, Entrypoint: CheckTCPPortState
    Action ended 19:24:07: GetPortStateConfigSrv.dll. Return value 1.
    MSI (c) (14:C8) [19:24:07:953]: Doing action: AI_DATA_SETTER_5
    Action 19:24:07: AI_DATA_SETTER_5.
    Action start 19:24:07: AI_DATA_SETTER_5.
    MSI (c) (14:C8) [19:24:07:953]: Note: 1: 2262 2: CustomAction 3: -2147287038
    MSI (c) (14:C8) [19:24:07:968]: Transforming table CustomAction.
    MSI (c) (14:C8) [19:24:07:968]: PROPERTY CHANGE: Modifying CustomActionData property. Its current value is '127.0.0.1|5485|PORT_CONFIG_IS_FREE'. Its new value: '0.0.0.0|5482|PORT_SL_IS_FREE'.
    Action ended 19:24:07: AI_DATA_SETTER_5. Return value 1.
    MSI (c) (14:C8) [19:24:07:968]: Doing action: GetPortStateSL.dll
    Action 19:24:07: GetPortStateSL.dll.
    Action start 19:24:07: GetPortStateSL.dll.
    MSI (c) (14:C8) [19:24:07:984]: Note: 1: 2262 2: CustomAction 3: -2147287038
    MSI (c) (14:C8) [19:24:08:000]: Transforming table CustomAction.
    MSI (c) (14:C8) [19:24:08:000]: Note: 1: 2262 2: Binary 3: -2147287038
    MSI (c) (14:C8) [19:24:08:015]: Transforming table Binary.
    MSI (c) (14:18) [19:24:08:031]: Invoking remote custom action. DLL: C:\DOCUME~1\STEELW~1\LOCALS~1\Temp\MSI5B.tmp, Entrypoint: CheckTCPPortState
    Action ended 19:24:08: GetPortStateSL.dll. Return value 1.
    MSI (c) (14:C8) [19:24:08:078]: Doing action: AI_DATA_SETTER_6
    Action 19:24:08: AI_DATA_SETTER_6.
    Action start 19:24:08: AI_DATA_SETTER_6.
    MSI (c) (14:C8) [19:24:08:078]: Note: 1: 2262 2: CustomAction 3: -2147287038
    MSI (c) (14:C8) [19:24:08:093]: Transforming table CustomAction.
    MSI (c) (14:C8) [19:24:08:093]: PROPERTY CHANGE: Modifying CustomActionData property. Its current value is '0.0.0.0|5482|PORT_SL_IS_FREE'. Its new value: '127.0.0.1|5483|PORT_IVR_IS_FREE'.
    Action ended 19:24:08: AI_DATA_SETTER_6. Return value 1.
    MSI (c) (14:C8) [19:24:08:093]: Doing action: GetPortStateIVR.dll
    Action 19:24:08: GetPortStateIVR.dll.
    Action start 19:24:08: GetPortStateIVR.dll.
    MSI (c) (14:C8) [19:24:08:109]: Note: 1: 2262 2: CustomAction 3: -2147287038
    MSI (c) (14:C8) [19:24:08:125]: Transforming table CustomAction.
    MSI (c) (14:C8) [19:24:08:125]: Note: 1: 2262 2: Binary 3: -2147287038
    MSI (c) (14:C8) [19:24:08:140]: Transforming table Binary.
    MSI (c) (14:DC) [19:24:08:156]: Invoking remote custom action. DLL: C:\DOCUME~1\STEELW~1\LOCALS~1\Temp\MSI5C.tmp, Entrypoint: CheckTCPPortState
    Action ended 19:24:08: GetPortStateIVR.dll. Return value 1.
    MSI (c) (14:C8) [19:24:08:203]: Doing action: AI_DATA_SETTER_7
    Action 19:24:08: AI_DATA_SETTER_7.
    Action start 19:24:08: AI_DATA_SETTER_7.
    MSI (c) (14:C8) [19:24:08:203]: Note: 1: 2262 2: CustomAction 3: -2147287038
    MSI (c) (14:C8) [19:24:08:218]: Transforming table CustomAction.
    MSI (c) (14:C8) [19:24:08:218]: PROPERTY CHANGE: Modifying CustomActionData property. Its current value is '127.0.0.1|5483|PORT_IVR_IS_FREE'. Its new value: '0.0.0.0|5090|PORT_TUNNEL_IS_FREE'.
    Action ended 19:24:08: AI_DATA_SETTER_7. Return value 1.
    MSI (c) (14:C8) [19:24:08:218]: Doing action: GetPortStateTUNNEL.dll
    Action 19:24:08: GetPortStateTUNNEL.dll.
    Action start 19:24:08: GetPortStateTUNNEL.dll.
    MSI (c) (14:C8) [19:24:08:234]: Note: 1: 2262 2: CustomAction 3: -2147287038
    MSI (c) (14:C8) [19:24:08:250]: Transforming table CustomAction.
    MSI (c) (14:C8) [19:24:08:250]: Note: 1: 2262 2: Binary 3: -2147287038
    MSI (c) (14:C8) [19:24:08:265]: Transforming table Binary.
    MSI (c) (14:28) [19:24:08:281]: Invoking remote custom action. DLL: C:\DOCUME~1\STEELW~1\LOCALS~1\Temp\MSI5D.tmp, Entrypoint: CheckTCPPortState
    Action ended 19:24:08: GetPortStateTUNNEL.dll. Return value 1.
    MSI (c) (14:C8) [19:24:08:312]: Doing action: AI_DATA_SETTER_24
    Action 19:24:08: AI_DATA_SETTER_24.
    Action start 19:24:08: AI_DATA_SETTER_24.
    MSI (c) (14:C8) [19:24:08:328]: Note: 1: 2262 2: CustomAction 3: -2147287038
    MSI (c) (14:C8) [19:24:08:343]: Transforming table CustomAction.
    MSI (c) (14:C8) [19:24:08:343]: PROPERTY CHANGE: Modifying CustomActionData property. Its current value is '0.0.0.0|5090|PORT_TUNNEL_IS_FREE'. Its new value: '127.0.0.1|5488|PORT_QUEUE_IS_FREE'.
    Action ended 19:24:08: AI_DATA_SETTER_24. Return value 1.
    MSI (c) (14:C8) [19:24:08:343]: Doing action: CheckTCPPortStateQUEUE
    Action 19:24:08: CheckTCPPortStateQUEUE.
    Action start 19:24:08: CheckTCPPortStateQUEUE.
    MSI (c) (14:C8) [19:24:08:343]: Note: 1: 2262 2: CustomAction 3: -2147287038
    MSI (c) (14:C8) [19:24:08:375]: Transforming table CustomAction.
    MSI (c) (14:C8) [19:24:08:375]: Note: 1: 2262 2: Binary 3: -2147287038
    MSI (c) (14:C8) [19:24:08:390]: Transforming table Binary.
    MSI (c) (14:08) [19:24:08:406]: Invoking remote custom action. DLL: C:\DOCUME~1\STEELW~1\LOCALS~1\Temp\MSI5E.tmp, Entrypoint: CheckTCPPortState
    Action ended 19:24:08: CheckTCPPortStateQUEUE. Return value 1.
    MSI (c) (14:C8) [19:24:08:484]: Doing action: AI_DATA_SETTER_9
    Action 19:24:08: AI_DATA_SETTER_9.
    Action start 19:24:08: AI_DATA_SETTER_9.
    MSI (c) (14:C8) [19:24:08:484]: Note: 1: 2262 2: CustomAction 3: -2147287038
    MSI (c) (14:C8) [19:24:08:515]: Transforming table CustomAction.
    MSI (c) (14:C8) [19:24:08:515]: PROPERTY CHANGE: Modifying CustomActionData property. Its current value is '127.0.0.1|5488|PORT_QUEUE_IS_FREE'. Its new value: '127.0.0.1|4516|TRUE'.
    Action ended 19:24:08: AI_DATA_SETTER_9. Return value 1.
    MSI (c) (14:C8) [19:24:08:515]: Doing action: CheckTCPPortStateWallboard
    Action 19:24:08: CheckTCPPortStateWallboard.
    Action start 19:24:08: CheckTCPPortStateWallboard.
    MSI (c) (14:C8) [19:24:08:515]: Note: 1: 2262 2: CustomAction 3: -2147287038
    MSI (c) (14:C8) [19:24:08:531]: Transforming table CustomAction.
    MSI (c) (14:C8) [19:24:08:546]: Note: 1: 2262 2: Binary 3: -2147287038
    MSI (c) (14:C8) [19:24:08:562]: Transforming table Binary.
    MSI (c) (14:24) [19:24:08:578]: Invoking remote custom action. DLL: C:\DOCUME~1\STEELW~1\LOCALS~1\Temp\MSI5F.tmp, Entrypoint: CheckTCPPortState
    MSI (c) (14!18) [19:24:08:625]: PROPERTY CHANGE: Adding TRUE property. Its value is 'TRUE'.
    Action ended 19:24:08: CheckTCPPortStateWallboard. Return value 1.
    MSI (c) (14:C8) [19:24:08:625]: Skipping action: PortIsNotFreeSIP_UDP (condition is false)
    MSI (c) (14:C8) [19:24:08:625]: Skipping action: PortIsNotFreeConfigSrv (condition is false)
    MSI (c) (14:C8) [19:24:08:625]: Skipping action: PortIsNotFreeSIP_TCP (condition is false)
    MSI (c) (14:C8) [19:24:08:625]: Skipping action: PortIsNotFreeSIP_PROXY (condition is false)
    MSI (c) (14:C8) [19:24:08:625]: Skipping action: PortIsNotFreePGSQL (condition is false)
    MSI (c) (14:C8) [19:24:08:625]: Skipping action: PortIsNotFreeHTTP (condition is false)
    MSI (c) (14:C8) [19:24:08:625]: Skipping action: PortIsNotFreeSL (condition is false)
    MSI (c) (14:C8) [19:24:08:625]: Skipping action: PortIsNotFreeIVR (condition is false)
    MSI (c) (14:C8) [19:24:08:625]: Skipping action: PortIsNotFreeTUNNEL (condition is false)
    MSI (c) (14:C8) [19:24:08:625]: Skipping action: PortIsNotFreeQUEUE (condition is false)
    MSI (c) (14:C8) [19:24:08:625]: Doing action: FindRelatedProducts
    Action 19:24:08: FindRelatedProducts. Searching for related applications
    Action start 19:24:08: FindRelatedProducts.
    MSI (c) (14:C8) [19:24:08:625]: Note: 1: 2262 2: Upgrade 3: -2147287038
    MSI (c) (14:C8) [19:24:08:640]: Transforming table Upgrade.
    Action ended 19:24:08: FindRelatedProducts. Return value 1.
    MSI (c) (14:C8) [19:24:08:640]: Skipping action: AI_DOWNGRADE (condition is false)
    MSI (c) (14:C8) [19:24:08:640]: Doing action: SetPropertyToCreateProvPath
    Action 19:24:08: SetPropertyToCreateProvPath.
    Action start 19:24:08: SetPropertyToCreateProvPath.
    MSI (c) (14:C8) [19:24:08:656]: Note: 1: 2262 2: CustomAction 3: -2147287038
    MSI (c) (14:C8) [19:24:08:671]: Transforming table CustomAction.
    MSI (c) (14:C8) [19:24:08:671]: PROPERTY CHANGE: Modifying SECURE_PROVISIONING property. Its current value is '3CX'. Its new value: 'C:\Documents and Settings\All Users\Application Data\3CX\Data\Http\Interface\provisioning\07568l5zqk'.
    Action ended 19:24:08: SetPropertyToCreateProvPath. Return value 1.
    MSI (c) (14:C8) [19:24:08:671]: Doing action: LaunchConditions
    Action 19:24:08: LaunchConditions. Evaluating launch conditions
    Action start 19:24:08: LaunchConditions.
    MSI (c) (14:C8) [19:24:08:671]: Note: 1: 2262 2: LaunchCondition 3: -2147287038
    MSI (c) (14:C8) [19:24:08:687]: Transforming table LaunchCondition.
    MSI (c) (14:8C) [19:24:08:703]: Note: 1: 2262 2: Binary 3: -2147287038
    MSI (c) (14:8C) [19:24:08:718]: Transforming table Binary.
    3CX PhoneSystem cannot be installed on the following Windows versions: Windows NT 4.0, Windows 2000, Windows XP x86, Windows Server 2003 x86, Windows Vista x86, Windows Server 2008 x86
    MSI (c) (14:C8) [19:24:11:000]: Note: 1: 2262 2: Error 3: -2147287038
    MSI (c) (14:C8) [19:24:11:015]: Transforming table Error.
    MSI (c) (14:C8) [19:24:11:031]: Product: 3CX PhoneSystem -- 3CX PhoneSystem cannot be installed on the following Windows versions: Windows NT 4.0, Windows 2000, Windows XP x86, Windows Server 2003 x86, Windows Vista x86, Windows Server 2008 x86
    Action ended 19:24:11: LaunchConditions. Return value 3.
    MSI (c) (14:C8) [19:24:11:046]: Doing action: FatalError
    Action 19:24:11: FatalError.
    Action start 19:24:11: FatalError.
    MSI (c) (14:C8) [19:24:11:046]: Note: 1: 2262 2: CustomAction 3: -2147287038
    MSI (c) (14:C8) [19:24:11:062]: Transforming table CustomAction.
    10,368
    228
    Very strange, I've installed it on Four, Win XP Pro, X86 based systems, all Intel Atom units. You are sure that this is version 11 you are trying to install?
    Just went back and scanned your post, you are trying to install version 12 (but posted in the version 11 forum). Version 11 will work on X86, Version 12 won't, however version 12 will run on Windows 7 X86. I have a Version 12 test unit up running Win 7 Pro on an Atom 230 (X86).
