Installation Error
Discussion in '3CX Phone System - General' started by fgwing, Oct 2, 2008.
  1. fgwing
    Sep 30, 2008
    I am having trouble installing the 3CX SIP-PBX. This error message appears while the installation is in progress...
    Error: Failed to startthe Service:3CX Phone System Database Server
    And then It says the installation was interrupted. Your system has not been modified. And the installation fails.
    I installed .NET Framework as instructed by the installation on the first try.
    P4 2.4GHz 512MB
    WinXP SP2
    Firewall if Off
    User: Administrator
    Any ideas?
    Thx,
    FGW
  2. KrisHansen
    Apr 30, 2008
    22
    Check the application Event Log for any errors/warnings during the time of the install. Google that error/Post it in reply here.
  3. alexmallia
    alexmallia New Member
    3CX Support
    Aug 4, 2008
    130
    This problem looks quite complicated to troubleshoot via forums. To get technical support on this one, you can contact our technical support (This requires commercial edition with support package). If you have a commercial edition, but no support package, you can purchase one here:
    https://erp.3cx.com/orderform/support.aspx
  4. fgwing
    Sep 30, 2008
    thank's for your reply. I ran the installation on a fresh WinXP SP2 install w/.NET Framework and it is now working!!
    /FG
