Installation Issues
Discussion in '3CX Phone System - General' started by iwray, Jul 12, 2010.
  1. iwray
    Jul 12, 2010
    I am having an issue with the installation, i have set it up so that when it receives a call that it would be transfered to the digital receptionist, once there it would play an audio file but I can not get through the server activity log reads
    12:53:17.516 [CM102001]: Authentication failed for SipReq: INVITE 6474787854@99.249.129.31 tid=3410b645 cseq=INVITE contact=5199131304@174.137.63.202 / 103 from(wire); Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
    12:53:17.516 [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
    INVITE sip:6474787854@99.249.129.31 SIP/2.0
    Via: SIP/2.0/UDP 174.137.63.202:5060;branch=z9hG4bK3410b645;rport=5060
    Max-Forwards: 70
    Contact: <sip:5199131304@174.137.63.202>
    To: <sip:6474787854@99.249.129.31>
    From: "5199131304"<sip:5199131304@174.137.63.202>;tag=as3a9a552e
    Call-ID: 70482e3163d398cd1ed7954038a292a2@174.137.63.202
    CSeq: 103 INVITE
    Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY
    Date: Mon, 12 Jul 2010 16:53:13 GMT
    Proxy-Authorization: Digest username="114664",realm="3CXPhoneSystem",algorithm=MD5,uri="sip:6474787854@99.249.129.31",nonce="414d535c024bd97d35:cf10beecc1d19c2cd16d1b4ec9cbe471",response="bdd4527cd7eb02f04661d4d9a67bb64a"
    Supported: replaces
    User-Agent: VoIPMS/SERAST
    Content-Length: 0
    Remote-Party-ID: "5199131304" <sip:5199131304@174.137.63.202>;privacy=off;screen=no
  2. MichaelB
    MichaelB Member
    3CX Support
    Aug 25, 2009
    407
    8
    Hi Irway,
    I got confused on what is your problem due you mentioned Installation problem with Digital Receptionist. Can you explain in more details.
    Thanks and Regards
  3. iwray
    Jul 12, 2010
    I am trying to set up this system for my house, I have ordered a couple of spa941 phones to work with the system but the phones have not arrived, but i thought i could test the system but getting a voip provider and setting up the provider in 3cx. I figured that I could have 3cx answer the call using the digital receptionist and playing an audio file to determine that my voip provider and 3cx were communicating, I am new to pbx but from the log it looks like 3cx receives the call but can not answer it and I am not sure why. The server log provided me with 2 errors but i am unsure of how to correct them.
    Thank you for your reply
  4. mhanson
    mhanson New Member
    Nov 6, 2008
    186
    There is your issue right there.
    Your system cannot validate the source of the call.
    Give this article a quick read through, adjust according, and post results.
    http://www.3cx.com/blog/docs/source-identification-issues/
    Perhaps you could add some screen shots of your current setup.
  5. chrisneal
    Nov 20, 2008
    27
    Do you have the VOIP provider configured for Registration or no registration.. (Many providers only want to route to an IP address and don't actually register... If that is the case you may want to go to the "Source ID" on the Edit Provider and add a match for Contact: Host Part > Variable "GWHostPort" gateway/provider host/port. That way the inbound call can be identified based on the IP of the gateway.
  6. iwray
    Jul 12, 2010
    Thank you mhanson that fixed it
