Installation not working
Discussion in '3CX Phone System - General' started by netsist, Mar 14, 2008.
  1. netsist
    Mar 14, 2008
    I installed the free edition of 3CX phone system and unable to get to panel
  2. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    http://localhost:5481 is not working?
    does you open the ports?
    check is the services started properly maybe something is blocking, like firewall or router
    wich version are u using? windows and so on
    cheers
  3. netsist
    Mar 14, 2008
    I already opened all the ports, but don't know if running IIS at the same time trying to launh 3CX has any effects as its complaining of an error Http Apache???????, using Windows XP
  4. techknows
    Mar 15, 2008
    7
    Its always been a straight forward install; I would strip out the install and try it again... the localhost link about should work on the host machine without any port forwarding....
  5. netsist
    Mar 14, 2008
    i have uninstalled and installed again, even tried stopping iis to check if this would work???????, could there be a conflict with the original installation of php for iis???/
