Installation problem CRC Failure
Discussion in '3CX Phone System - General' started by Anonymous, Nov 24, 2006.
  1. Anonymous
    Anonymous Guest
    Hello All
    I downloaded sucessfully and when i try to insall it gives me a error message that the file is corrupted or crc fail how should i go about and install it ..as i m not able to intall at all
    Help will appreciated
    Irfan
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,991
    306
    CRC
    That sounds like a corrupted download. Please re-download the software again.
