Installation Problem
Discussion in '3CX Phone System - General' started by Mauro, May 15, 2008.
  1. Mauro
    May 15, 2008
    Hi all
    i have a prolem with installation of version 5.1 in a win2003 r2 system.
    in the event log i have this entry :
    Product: 3CX PhoneSystem -- Error 1720. There is a problem with this Windows Installer package. A script required for this install to complete could not be run. Contact your support personnel or package vendor. Custom action RemoveDummyUsersFolders.vbs script error -2147023838, : Line 468, Column 2,
    Per ulteriori informazioni, consultare la Guida in linea e supporto tecnico all'indirizzo http://go.microsoft.com/fwlink/events.asp.
    Can anyone help me?
    Many thanks
    Mauro
  2. coelhopsi
    May 7, 2008
    84
    Line 468 of the referenced script does the following:
    Code:
    Set oWMI = GetObject("winmgmts:\\" & strComputer & "\root\cimv2")
    It's a simple WMI connection opening, so I suspect there may be a problem with WMI on your server...
  3. Mauro
    May 15, 2008
    Hi, many thanks.
    works now.
    Mauro
