Installation problem
Discussion in '3CX Phone System - General' started by jematab, Aug 6, 2008.
  1. jematab
    Jul 29, 2008
    I can't install 3CX I have "3CX PhoneSystem Setup Wizard ended prematurely"
    I'm under win 2000 with a via processor
    I join install log
    Can you help me ?
