Installation use of system partition
Discussion in '3CX Phone System - General' started by 101smart, Jan 24, 2013.
  1. 101smart
    Dec 13, 2010
    I tried to install 3cx on a windows 2008 standard server it seems to put over a gigabyte of data onto the system partition even though i have selected another drive to install it on. Does anyone know why it does this and how i can stop it from putting data on the system partition as there is just over a 1gb of space on it and trying to install the software fills the drive up.
