installation's problem, I need help
Discussion in '3CX Phone System - General' started by Trello, Nov 2, 2007.
  1. Trello
    Nov 2, 2007
    I am having problems with a new installation of the FREE version of 3cx, installed on Win XP SP 2 HUN. When the installation starts, I get a massage:
    Supported operating System are the following:
    Windows XP SP 2 or later etc...
    The installation is breaking after this massage.
    I tried it 3 different computers - they have got equal system - but i can't installed it.
    What is the problem??
    I'm waiting your answer.
    Best regards:
    Béla,Acél
    Budapest-Hungary
  2. Mori
    Mori New Member
    Mar 23, 2007
    223
    Language
    Hi.
    Not 100% sure, but could it be trouble caused by your OS language?
