Installing 3CX on any other drive than C:
Discussion in '3CX Phone System - General' started by colin2710, Nov 1, 2007.
  1. colin2710
    Oct 29, 2007
    28
    Hi all,
    I have able to install 3CX successfully on Drive C: on two of our servers (testing only), but I can't get it to install on any (tried 3 servers) on drive D: or drive E:. The error I get is database error: incorrect user name and password (or something similar) - we looked at permissions, but it still would not work - works fine if we install on drive: C: Can any one help?
    For interest, we think that 3CX is just what we are looking for and if version 4 (does what it says on the tin) than we will be buying at least the "Professional Edition".
    Well done all
    Regards - Colin
  2. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    I've installed this on D: several times without any issues on Server 2003 & SBS2003.
    haven't tried on XP.
    Can you create folders and files with the account you are logging in with to install 3CX?
  3. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Windows XP works fine as well.
  4. colin2710
    Oct 29, 2007
    28
    Hi Rob & Ricky,
    All the servers I have installed it on have been Windows 2000 - fully service packed and logged on as an administrator.
    Yes - I can create files and folders - our IT guy says that it must be something to do with the database wanting to be on C:. I am not so sure of that.
    I just can't think of anything else.
    Regards - Colin
  5. ra81
    Oct 24, 2007
    8
    installation log file
    Can you send me install.log from the 3CX PhoneSystem program files please?
