Installing 3CX on Exchange 2007 Server
Discussion in '3CX Phone System - General' started by PCITim, Jul 6, 2009.
  1. PCITim
    Jul 3, 2009
    I seems that it is possible to install 3CX on the exchange server, is this reconmended? What are the pros & cons. Our Exchange server is a very robust machine with very light e-mail traffic. (dual, quad-core zeon, 8GB ram, 450 GB 15k SCSI raid 5)
  2. bluetel2
    bluetel2 Member
    Oct 16, 2008
    377
    8
    hello,
    you can try it. it's can work but it's not advise, because exchange have need more performance.
    you can try to see if it's work, install 3cx on IIS.
    don't forget, 3cx use more disk access, and it need good network (network card, switchs, and link connexion cat5e).
    have good day
  3. Ase
    Ase
    Jan 12, 2009
    58
    Hi PCITim,
    If you can get it to work, please post info how you did it.
    I have put a lot of time to it, but not been able to get it to work.
    //Ase
  4. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Ase,
    You know that 3CX PBX is ready to work even on the same host(server)...
    Thanks for your further comments ;)
  5. Ase
    Ase
    Jan 12, 2009
    58
    Hi Stepan,
    This was the result when I discussed the issue eralier (ofcourse I can run it on a virtual server, but that is not what I am looking for):
    No, the software can not be run on the same server. We will review the FAQ. Keep things easy and use the inbuilt voice mail server, its much more performant and setup is much easier.
    Nick Galea
    http://www.3cx.com
    Read & comment on 3CX Phone System news on the 3CX blog
    You can find the hole thread here: http://www.3cx.com/forums/3cx-exchange-2007-unified-messaging-9213.html
  6. SY
    3CX Support
    Jan 26, 2007
    1,825
    Ase,
    You forgot to "quote" Nick's post :)
    Nick's answer is completely fair and correct. The products will not work on the same server and FAQ provided for our product should specify it...
    Microsoft provides technical support and you may ask them why it is not possible and/or not advisable(most probably) for Microsoft Exchange Server.
