Installing 3CX on Linux Version: Debian 9 Stretch
Discussion in '3CX Phone System - General' started by nb, Jun 29, 2017.
  1. nb
    nb Support Team
    Jun 7, 2007
    2,153
    171
    #1 nb, Jun 29, 2017
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    814
    49
    Do I have to worry if the “Automatic updates” is set to Enable or should I disable this function?
  3. nb
    nb Support Team
    Jun 7, 2007
    2,153
    171
    Automatic updates do not check for OS Updates.
    Automatic updates just download Critical security updates but you will always remain on the base OS system.
  4. complex1
    Jan 25, 2010
    814
    49
    Hi nickybrg,
    Thank you for this clarification.
  5. cobaltit
    cobaltit Well-Known Member
    Mar 22, 2012
    1,580
    237
