Installing 3CX system on Per installed PHP and Apache
Discussion in '3CX Phone System - General' started by omid1979, Jan 31, 2007.
  1. omid1979
    Jan 28, 2007
    Dear All ,
    I want to install 3CX system on my desktop computer , I was install PHP and IIS Installed on my system , I want to know how I can install 3CX on this system without any problem , because I was install it and recive debug error on confused php version and web server port ,
    how I can configure php and web server on 3CX system
    Waiting for your reply
    regards
    Omid Hosseini
  2. 3CXsupport
    3CXsupport New Member
    Aug 21, 2006
    193
    Hi Omid,
    You do not need to configure anything.
    Our software will unload apache, php and postgress within our directory under program files. You will have apache running with php (this will all be set up on its own during installation). You need not to worry about the webservers conflicting, IIS will run on port 80 using it's own PHP and whatever ports you may have configured it to listen to, meanwhile (our) apache will have it's own php and listen on tcp port 5481.
    It should work without problems and should be able to run the installtion and not worry about any of all this.
