Installing 3cx system on Windows 7 64 bit
Discussion in '3CX Phone System - General' started by varietel, Jan 12, 2011.
  1. varietel
    Oct 29, 2010
    22
    Has anybody been able to install 3CX V.9 on Windows 7 Home Premier 64 bit successfully. I get the following error in my installation:
    Operation failed with 0x8007000B
    An attempt was made to load a program with an incorrect format.
    It was able to install it on Windows XP successfully.
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,406
    81
    Re-Download
    Re-Install :)
  3. jtrollen
    May 17, 2010
    21
    I can't help with the error code, but I'm running it on Windows 2008 R2 64-bit with no problems. The code base is similar between Windows 2008 and Windows 7 so I would think it would work. One thing you could try is to ctrl+ right-click the installer and choose "Run As Administrator" when you install it. I've had to do that a few times to make things work with other programs.
