Installing an ATA ** FIX PROVIDED
Discussion in '3CX Phone System - General' started by bduke08021, Jul 23, 2010.
  1. bduke08021
    Jun 20, 2009
    34
    i am looking at the Linksys SPA-3102 for analog ext on my 3cx system. Where do i set it up in the IP PBX, under "Add Ext." or PSTN Devices. Looks like if i set it up under PSTN, it becomes a gateway for incoming calls, under add ext, the template doesn't show up in the drop down, just Linksys.
  2. carolinainnovative
    May 4, 2009
    369
    6
    Re: Installing an ATA
    You would set it up under phone extensions. There is not currently a template for that ATA. You'll have to do it manually.
  3. nb
    nb Support Team
    Jun 7, 2007
    2,153
    175
    Hi - As salter mentioned, we do not provision ATA part of the device. Just the Gateway section.
    To configure the ATA section follow this (without the fax part)
    http: //www.3cx.com/sip-phones/linksys-spa-3102-fax/ No longer available. New link: http://www.3cx.com/sip-phones/
    And all you need to do is go to the ATA section, enable the line and perform changes described in point 4 only.
  4. bduke08021
    Jun 20, 2009
    34
    ok so the ata accepts incoming calls, but i can not dial out to internal or external calls. Message "Called Number Does not Exist."
  5. bduke08021
    Jun 20, 2009
    34
    Since my last post, i found that the ata is only sending the first digit i dial to the 3cx. can not see why.
  6. leejor
    11,129
    330
    It may have something to do with the dialplan in the Linksys, if in fact you are certain that only one digit is being passed to 3CX. The 3CX logs will confirm this. Make sure that the dialplan matches what is recommended for use with 3CX on a Linksys ATA.
    The 3102 will work as both a Gateway and ATA, at the same time, as long as it is set up properly. As many have found, it can be a frustrating experience as there are a LOT of options. You may want to post the Line settings from your device.
  7. bduke08021
    Jun 20, 2009
    34
    it was the dial plan, the 3cx setup guide had me change it, i changed it back to default and now it works fine.
