Installing Error Port 5060(TCP)
Discussion in '3CX Phone System - General' started by kdecaigny, Sep 16, 2013.
  1. kdecaigny
    Sep 16, 2013
    I have been having a very hard time installing 3CX on Windows Server 2012 Essentials.
    I keep getting the following errors. I have reformatted the computer, reconfigured my router and have successfully installed
    3CX on another machine on the same network. (Although running Windows 8) Could anyone point me in the right direction on
    what I am doing wrong.
    Thank You!
  2. tarmeeb
    Aug 28, 2013
    19
    Try installing while your internet connection is disabled
  3. bardissi
    bardissi Member
    Jan 31, 2012
    318
    It seems like port 5060 is being used by another software on Server 2012 essentials according to your post.
  4. ian.watts
    ian.watts Active Member
    Apr 8, 2011
    532
    Open a Command Prompt as Administrator
    netstat -ban | clip
    Paste into notepad or some editor. If notepad.. ctrl-home to the top.
    ctrl-f to Find.. 5060.
    What you are looking for is something like this:
    TCP 0.0.0.0:5060 0.0.0.0:0 LISTENING
    someprocessname.exe
    That will be the process name listed under the port which it is listening on. The port and transport are the knowns here.. the question is what process is listening there.
    Disregard the ESTABLISHED lines or the UDP info.
    Lync?
    Exchange?
    "something" is already on the port.
    Nothing from a vanilla 2012 Essentials is.
  5. kdecaigny
    Sep 16, 2013
    Hi Ian!
    Your idea worked great and I have been able to locate the service that is running.
    It's from my motherboard (Asus) that has a wifi chip built in - one of the drivers
    is using port 5060 as a Wifi Go! Server. I will stop the service and hopefully be
    able to get my install working.
    Thank You!
    Kristopher
