Installing from ISO: Debian for 3CX
Discussion in '3CX Documentation' started by Bianca, Jan 26, 2017.
  1. Bianca
    3CX Support
    Dec 9, 2015
    49
    10
    #1 Bianca, Jan 26, 2017
  2. nathanmf
    May 29, 2017
    5
    I followed the instructions, including creating a bootable 3cx usb. But is didn't work for me, kept getting an error in the debian config..
  3. nb
    nb Support Team
    Jun 7, 2007
    2,099
    142
    Yes but what error?
  4. nathanmf
    May 29, 2017
    5
    It gives me this error after I press install:
  5. nb
    nb Support Team
    Jun 7, 2007
    2,099
    142
    Kernel Panic not syncing - when you see words like kernel panic or blue screens you dont need to come to the 3CX forum. For sure the problem is in the kernel which is in the lower bowels of the operating system.
    https://en.wikipedia.org/wiki/Kernel_panic
    A kernel panic (sometimes abbreviated as KP[1]), also known as computer death or PC death, is an action taken by an operating system upon detecting an internal fatal error from which it cannot safely recover. The term is largely specific to Unix and Unix-like systems; for Microsoft Windows operating systems the equivalent term is "Stop error" (resulting in a "Stop error screen," or colloquially, a "Blue Screen of Death").
  6. Cornelius Schoeman
    Aug 3, 2017
    I'm following these steps and was just wondering when to remove the USB stick as the first install I've done the server rebooted after the debian installation with the USB drive still connected to the server and it started all over again.#
    Kind Regards
    Cornelius
  7. nb
    nb Support Team
    Jun 7, 2007
    2,099
    142
    After OS is installed, and it reboots, you need to remove the USB otherwise as you stated, the install will load from USB again and it will erase everything again (You make the ISO Os bootstrap think that you want to reinstall again. )
    You need to remove the USB after the first reboot.. Which is normally after the OS has been installed.
  8. Cornelius Schoeman
    Aug 3, 2017
    Hi Nicky
    I've tried that now, removed the USB before it reboots. When the server reboots it gets stuck on "CLIENT MAC ADD" and DHCP.../. then says no boot file name received. I've checked the boot order and have set it to HDD but still no luck, the 3cx installation does not start. I've attached two pictures, one showing the no boot file received and the other is the boot order.
    Kind Regards
    Cornelius
  9. nb
    nb Support Team
    Jun 7, 2007
    2,099
    142
    What is the hardware? Can you send the exact specs?
    Is it a mini pc? What is the make, model?
    The reason I'm asking is because it could be some drivers are required... Send exact hardware setup where you see this problem.
  10. 3cxsupport@Summitusa.com
    Nov 24, 2009
    The 3CX Debian Installation from ISO instructions are very well done. Thank you!
    For what it is worth, i would like to just add one minor comment for anyone who is trying to install on a VLAN and needs to add a VLAN tag to the eth0 (or whatever the nic card is named) before being allowed access on the network.
    By default, the debian configuration included in the ISO package does NOT support VLAN tags without having to:
    1. add VLAN support to the system.
    1.1. $ sudo apt-get install vlan
    1.2. $ sudo modprobe 8021q
    1.3. $ echo 8021q | sudo tee -a /etc/modules
    (Note: insteat of the echo command in 1.3you can use vi or another text editor to add the above-mentioned 8021q kernel module to the /etc/modules configuration file to load it at the boot time) ​
    2. modify the /etc/network/interfaces file (below is an example or what the interfaces files should look like)
    2.1
    # This file describes the network interfaces available on your system
    # and how to activate them. For more information, see interfaces(5).
    # The loopback network interface
    auto lo
    iface lo inet loopback
    # The primary network interface
    allow-hotplug eth0
    iface eth0 inet dhcp
    # add vlan 700 on eth0 - static IP address
    auto eth0.700
    iface eth0.700 inet static
    address 10.100.10.77
    netmask 255.255.255.0
    3. Restart network with VLAN tag configured
    3.1 $ /etc/init.d/networking restart
    4. Verify that internet access (DNS resolution specifically) works.
    4.1 $ ping 8.8.8.8
    4.2 $ ping google.com
    5. continue with the 3CX installation (meaning start from the Debian step that downloads the 3cx proconfig file)
    Thank you for your attention.
  11. Volkan
    Dec 14, 2017
    Hello
    After 15. step i ook an error what should i do ?
    [​IMG]
  12. nb
    nb Support Team
    Jun 7, 2007
    2,099
    142
    You did this manually?
    in 3cxpbx.list it should be :
    http://downloads.3cx.com/downloads/debian stretch main
    seems you put:
    http://downloads.3cx.com/downloads/debian stretch Release
    Also debian repositories in /etc/apt/sources.list are broken. Here's a sample of how it can be in stretch:
    deb http://ftp.gr.debian.org/debian/ stretch main contrib
    deb-src http://ftp.gr.debian.org/debian/ stretch main
    deb http://security.debian.org/ stretch/updates main
    deb-src http://security.debian.org/ stretch/updates main
    deb http://ftp.gr.debian.org/debian/ stretch-updates main
    deb-src http://ftp.gr.debian.org/debian/ stretch-updates main
    Copy all this carefully and you should be ok.
  13. Volkan
    Dec 14, 2017
    where is 3cxpbx.list locate ?
    i edit source.list and then what should i do ? I am new at linux sorry for that :(
  14. nb
    nb Support Team
    Jun 7, 2007
    2,099
    142
  15. leo81
    Jun 27, 2018
    Hey, i have one Problem, after installing from iso Debian 9 3cx, a can not see 3cx configuration page in the linux console. i see only : login. why is it so ?
    i have 3 time rebooted...or more.. no changes...
    thank you very much for your help
  16. nb
    nb Support Team
    Jun 7, 2007
    2,099
    142
    Install 3CX Again - this should work out of the box.
    This is a symptom of some system d services not starting - Can you check?
    or reinstall 3CX?
  17. leo81
    Jun 27, 2018
    Hello
    Thank you very much
    Ok, i have already installed this appl again, and it works
    I cannot login me into linux to create ssh access: to do
    Apt-get install openssh-server
    And change the sshd_config file.
    I see only 3CX configuration tool
    But i can not see login
    Can you help me here please ? is keyboard key, but which ? J
    Thank you for your help
    Best regards
    Leonid
  18. nb
    nb Support Team
    Jun 7, 2007
    2,099
    142
    not like this - linux already has an SSH server.
    You need to download putty (sshclient) and connect with putty to your linux machine.
