Installing on XP Professional 64 bit
Discussion in '3CX Phone System - General' started by aghufran, Dec 28, 2009.
  1. aghufran
    Dec 28, 2009
    Hello All,
    I am trying to install 3CX free version on my XP Pro 64 bit. It installs without any problem but at the end says that it cannot connect to the database server.
    When I go into Windows,settings and services to verify the status of all 3CX services they come up at not started though set on auto. When I try to start them they fail. When I follow the dependencies to start the chain, that also does not work.
    Would appreciate if someone could help.
    Thanks and regards,
    Abid Ghufran
