Installing the new beta
Discussion in '3CX Phone System - General' started by rascott757, Jan 23, 2007.
  1. rascott757
    Jan 13, 2007
    9
    Does it require that the old version be uninstalled, or should I install over it?
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,994
    306
    YOu can install over it and it should upgrade all settings. However i recommend doing a backup of the configuration data before that
