Installing to WES7 ?
Discussion in '3CX Phone System - General' started by pheitkemper, Sep 7, 2011.
  1. pheitkemper
    Aug 31, 2011
    5
    I am trying to install 3CX to Windows Embedded Standard 7. I am able to install using Abyss web server. However, I would like to install to IIS, but it errors out. I get a pop-up message saying "There was an error during the IIS configuration process. Your original IIS configuration will be restored."
    When I look at the install log, I see the above text. Below that I see that I get error 1603.
    The box has IIS 7 and .NET 4 installed.
    Suggestions?
    Thanks,
    Paul
  2. nbailey
    nbailey Member
    Jan 31, 2011
    359
    Hi Paul,
    Your best bet is to stick with a supported OS. http://www.3cx.com/blog/docs/supported-windows-versions/
    I don't know much about Windows Embedded Standard 7, but from what I understand I don't think it would be
    a viable server to install 3CX onto as it is used for POS terminals.
    Thanks,
    Nate
  3. pheitkemper
    Aug 31, 2011
    5
  4. nbailey
    nbailey Member
    Jan 31, 2011
    359
    yeah hardware wise np for sure. I think you will find support for this OS hard to find, I meet and speak with a lot of folks and this is a first for this OS for me. Good luck though, but really I would go with at best Windows 7 Ultimate imo.
    Thanks,
    Nate
