Installing under IIS on Server 2008 R2**IIS INSTALL FIXED
Discussion in '3CX Phone System - General' started by swim, Jul 20, 2010.
  1. swim
    Sep 23, 2008
    26
    Is there any documenation anywhere that details manually setting up IIS on Server 2008 R2 for 3CX Phone System Version 9
    as when I try to install 3CX using IIS I get an install error seen below
    Product: 3CX PhoneSystem -- Error 4020. There was an error during the IIS configuration process.
    Your original IIS configuration will be restored.
    Under bundled Abyss Web Server 3CX installs and runs ok
  2. MichaelB
    MichaelB 3CX Team
    3CX Support
    Aug 25, 2009
    415
    19
    Re: Installing under IIS on Server 2008 R2
    Hi, this is an error coming from IIS, and probably a misconfiguration of IIS.
    1. Send me the log file - C:\Users\Administrator\AppData\Local\Temp\2
    >3CXPhoneSystem_install.log
    2. I would also consider reading this article - http://www.3cx.com/blog/docs/troubleshooting-iis-ivr/
    Thanks and Regards
  3. nb
    nb Support Team
    Jun 7, 2007
    2,147
    173
    Def IIS problem. Remove IIS from Add/remove roles and add it again.
  4. swim
    Sep 23, 2008
    26
    Re: Installing under IIS on Server 2008 R2**IIS INSTALL PROBLEM
    Now working after reinstalling IIS :) a special thanks to Michael Borg for his documentation and help
