Instruktion polish version
Discussion in '3CX Phone System - General' started by Anonymous, Dec 4, 2006.
  1. Anonymous
    Anonymous Guest
    Mam instrukcje obslugi przetlumaczona na jezyk polski, wiec jesli ktos chce zapraszam. unox@go2.pl :lol:
  2. archie
    archie Well-Known Member
    3CX Support
    Aug 18, 2006
    1,299
    Thank you for care :) I will translate your message, for it not to be deleted:
    "I have user manual translated to polsih. If someone need it - you may write to unox@go2.pl"
    Best regards,
