- Joined
- Mar 14, 2018
- Messages
- 2
- Reaction score
- 0
I´m trying to perform a manual installation on a Debia 9 in a hosting service using Virtuozzo.
Distributor ID: Debian
Description: Debian GNU/Linux 9.2 (stretch)
Release: 9.2
Codename: stretch
First Problem, when I´m doing initial configuration through web config, the wizard stops in the "Choose Local Interface Screen", the interface list is empty and I can´t continue because it´s a required field.
Second try: Wiped out the entire machine (started a new instance) and got through Text interface for configure. O Text interface I was able to pass the "local interface" configuration (again, no interface list, but accepted only entering my IP) and finish the process. But main services fails to start.
I tried google it, in the forum, checking the logs but I´m blind here. Please, if someone could get me some thoughts...
Verifying "journalctl -xe" Output:
Release: 9.2
Codename: stretch
Code:
Starting other services...
Job for 3CXPhoneSystem01.service failed because a fatal signal was delivered causing the control process to dump core.
See "systemctl status 3CXPhoneSystem01.service" and "journalctl -xe" for details.
A dependency job for 3CXIVR01.service failed. See 'journalctl -xe' for details.
A dependency job for 3CXQueueManager01.service failed. See 'journalctl -xe' for details.
Starting Event Notification Service...
Lets Encrypt Trusted SSL Certificate created...SUCCESS
Done
Setup completed
Congratulations! Your 3CX Installation is ready.
Code:
-- Unit 3CXPhoneSystem01.service has begun starting up.
Mar 14 08:51:26 4rgfmdpv97 systemd[1]: 3CXPhoneSystem01.service: Main process exited, code=dumped, status=11/SEGV
Mar 14 08:51:26 4rgfmdpv97 systemd[1]: Failed to start 3CX PhoneSystem 01 SIP Server.
-- Subject: Unit 3CXPhoneSystem01.service has failed
-- Defined-By: systemd
-- Support: https://www.debian.org/support
-- Unit 3CXPhoneSystem01.service has failed.
-- The result is failed.
Mar 14 08:51:26 4rgfmdpv97 systemd[1]: 3CXPhoneSystem01.service: Unit entered failed state.
Mar 14 08:51:26 4rgfmdpv97 systemd[1]: 3CXPhoneSystem01.service: Failed with result 'core-dump'.
Mar 14 08:51:26 4rgfmdpv97 sudo[12941]: pam_unix(sudo:session): session closed for user root
Mar 14 08:51:26 4rgfmdpv97 sudo[12958]: phonesystem : TTY=pts/1 ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl start 3CXSystemService01
Mar 14 08:51:26 4rgfmdpv97 sudo[12958]: pam_unix(sudo:session): session opened for user root by (uid=0)
Mar 14 08:51:26 4rgfmdpv97 systemd[1]: Starting 3CX PhoneSystem 01 System Server...
-- Subject: Unit 3CXSystemService01.service has begun start-up
-- Unit 3CXSystemService01.service has begun starting up.
Mar 14 08:51:27 4rgfmdpv97 systemd[1]: Started 3CX PhoneSystem 01 System Server.
-- Subject: Unit 3CXSystemService01.service has finished start-up
-- Unit 3CXSystemService01.service has finished starting up.
-- The start-up result is done.
Mar 14 08:51:27 4rgfmdpv97 sudo[12958]: pam_unix(sudo:session): session closed for user root
Mar 14 08:51:28 4rgfmdpv97 sudo[12979]: phonesystem : TTY=pts/1 ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl start 3CXIVR01
Mar 14 08:51:28 4rgfmdpv97 sudo[12979]: pam_unix(sudo:session): session opened for user root by (uid=0)
Mar 14 08:51:28 4rgfmdpv97 systemd[1]: Starting 3CX PhoneSystem 01 SIP Server...
-- Subject: Unit 3CXPhoneSystem01.service has begun start-up
Mar 14 08:51:28 4rgfmdpv97 systemd[1]: 3CXPhoneSystem01.service: Main process exited, code=dumped, status=11/SEGV
Mar 14 08:51:28 4rgfmdpv97 systemd[1]: Failed to start 3CX PhoneSystem 01 SIP Server.
Mar 14 08:51:28 4rgfmdpv97 systemd[1]: Dependency failed for 3CX PhoneSystem 01 IVR Server.
-- Subject: Unit 3CXIVR01.service has failed
-- Unit 3CXIVR01.service has failed.
-- The result is dependency.
Mar 14 08:51:28 4rgfmdpv97 systemd[1]: 3CXIVR01.service: Job 3CXIVR01.service/start failed with result 'dependency'.
Mar 14 08:51:28 4rgfmdpv97 systemd[1]: 3CXPhoneSystem01.service: Unit entered failed state.
Mar 14 08:51:28 4rgfmdpv97 systemd[1]: 3CXPhoneSystem01.service: Failed with result 'core-dump'.
Mar 14 08:51:28 4rgfmdpv97 sudo[12979]: pam_unix(sudo:session): session closed for user root
Mar 14 08:51:28 4rgfmdpv97 sudo[12996]: phonesystem : TTY=pts/1 ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl start 3CXQueueManager01
Mar 14 08:51:28 4rgfmdpv97 sudo[12996]: pam_unix(sudo:session): session opened for user root by (uid=0)
Mar 14 08:51:38 4rgfmdpv97 systemd[1]: 3CXPhoneSystem01.service: Main process exited, code=dumped, status=11/SEGV
Mar 14 08:51:38 4rgfmdpv97 systemd[1]: Failed to start 3CX PhoneSystem 01 SIP Server.
