integration between 3CX and Salesforce.com
Discussion in '3CX Phone System - General' started by aguilar, Apr 17, 2008.
  1. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    hello
    i followed the instructions for make integration between 3CX and Salesforce.com
    have port 5481 tcp/udp open and testing i get a nice 404 not found
    is there something i missed?
    thanks in advance
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,991
    306
    In that case you have not copied or configured the string correctly. Please follow the steps in the description correctly. You dont need to open any ports, the call between your application and the phone system is done on the local network
  3. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    Hello Nick
    the string is:
    HYPERLINK("http://192.168.1.88:5481/make_call.php?extnum=127&vmpin=127&to="&Phone,"Click here to call this contact with 3CX") wich generates
    http://192.168.1.88:5481/make_call.php?extnum=127&vmpin=127&to=050259975
    even running like localhost i get the same 404 The requested URL /make_call.php was not found on this server.
    the server box is at 192.168.1.88
    the ext # 127
    regards
