integration between cisco cme and 3cx phone system
Discussion in '3CX Phone System - General' started by mshanawaz, Apr 25, 2015.
  1. mshanawaz
    Apr 25, 2015
    Please anybody can tell me how to integrate between cisco cme and 3cx phone system.
    can you tell step by step.
    Regards
  2. hivanov
    Apr 25, 2012
    22
    Hi mate,
    Look at this topic : http://www.3cx.com/forums/call-manager-express-3cx-10585.html
    I think this will do the job with little modifications according your environment and needs.
    Good Luck ! :D
    Hristo
