Integration Updates - Release Notes
Discussion in 'Ideas' started by supplenta, Dec 7, 2016.
  1. supplenta
    Oct 3, 2012
    35
    I was wondering if there was anywhere that displays what patches/fixes/updates have been made against an integration module.
    I noticed that my 'Freshdesk' module had an update but not sure what this fixes/patches etc...
    Thanks.
  2. nb
    nb Support Team
    Jun 7, 2007
    2,097
    142
    Yes we are working on it. We do not have at the moment.
    The freshdesk module has an update yes.
    Yesterday they changed their TLS version. So we had to make an emergency fix.
  3. pat71
    Mar 17, 2016
    44
    When I finish a call the "ticket tab" feature open in Freshdesk. I want it to open up when I answer the call instead. The only way to make it work that way is not to answer the call in the 3CX client but on my desk phone. Then I have both the contact card and the ticket tab open at the same time. Is there any way to get it to work so even if I answer the call in the 3CX client?
    Is there a way to modify the code in the
    "C:\ProgramData\3CXPhone for Windows\PhoneApp\DotNetScripts\FreshDesk".
    In the file "FreshDeskSession.cs" can i do something to make it work.
  4. Andreas Paradisiotis
    Apr 7, 2017
    53
    11
    Hello pat71
    The standard behavior of the Fresh Desk plug in is to open the ticket page when the call finish . If you want to modify that behavior please replace the attached files (FreshDeskSession.cs, FreshDeskPlugin.cs) in the directory C:\ProgramData\3CXPhone for Windows\PhoneApp\DotNetScripts\FreshDesk . With this modifications you will be able to see the ticket page after your answer the call from the 3CX client
    Thank you . If you have any other questions please let me know
    pat71 and jed like this.
  5. pat71
    Mar 17, 2016
    44
    Hi Andreas,
    I will try that,
    Many thanks.
    Regards,
