Integration with Asterisk
Discussion in '3CX Phone System - General' started by bundzmm, Sep 12, 2017.
  1. bundzmm
    Sep 12, 2017
    Hello. I have a problem with trunking Asterisk-3CX. We downloaded and installed "3CX PBX Edition" for testing this system in our infrastructure. Then we created outgoing trunk with our Asterisk. Everything ok, calls going from 3CX client to my Grandstream IP-phone succesfly. But! On my IP-phone I see trunk number (not 3CX user number) in incoming calls. That's why I can't call back to 3CX user. Which parameters configured wrong? I tried change "From : Display Name" and "From : User Part" but I had no good results.
  2. IoannisM_3CX
    IoannisM_3CX Support Team
    Aug 10, 2017
    229
    18
    Hello @bundzmm
    In order to do that you'll have to configure 3CX-Asterisk bridge as explained in the guide. This configuration is the only one supported by 3CX in order for everything to function correctly. At the moment you see the trunk number because the call is routed through your provider and not though a bridge,that is why you see the main trunk number and non of the callers information.
    Thank you
