integration with my CRM
Discussion in 'CRM / Helpdesk / App Integration' started by tszczotkowski, Apr 17, 2018 at 12:45 PM.
  1. tszczotkowski
    Monday
    hello,
    I'm new in this forum and i have problem.
    I must integration clinet 3cx with my CRM. crm in website and i don't know better write program in C# as plugin in 3cx or add program to behavior as bat or jar.
    so where i can look for documentation C# to 3cx to write programas and plugins?
    Program must recognize extension and external number and show website user where recognize external numer.
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    893
    66
  3. Umka
    Wednesday
    5
    Hi! Help me please. I created the plugin but I do not understand whether it was connected to the client or not. How do I find out? The plugin is not captured by the application, if you try to remove it, it is freely deleted. Hence the library does not work? I did everything according to the instructions. Professional, all redist are. VS2017.
  4. edossantos
    Jun 27, 2007
    893
    66
    If you're using the client side approach, please ensure that you have a PRO license activated on your 3CX server. That only works in that case.
  5. Umka
    Wednesday
    5
    PRO is active!
    Plugins work VERY strange. https://www.3cx.com/blog/docs/3cxphone-for-windows-api/ - this code incorrect. And now we're create simple Class Library Project C#.
    1. The key is not valid in the example, namely <add key="CRMPlugin" value="CallNotifier,3CXPhoneTapiPlugin,CallTriggerCmdPlugin"/> - put in 3CXWin8Phone.user.config - WRONG WAY.
    2. Plugins once again created only work if the key is added -
    <add key = "CRMPlugin" value = "My, DotNetScriptPlugin" /> where "My" are our own class.
    3. The example supplied with the note how to write your plug-in is already there at the installation and nothing needs to be copied as written in the description of item 3.
    Which is the right approach I should use when developing the client side plug-in. The code sample and the Explanations to it are not correct.
    And now the question is, so there is the correct documentation, how to develop your plug-in? Since the present version of the note is not correct ...
    #5 Umka, Apr 18, 2018 at 12:19 PM
  6. Umka
    Wednesday
    5
    Screenshot PRO ACTIVE added:
      File size:
      51.4 KB
  7. Umka
    Wednesday
    5
    Anybody help me please. Can we get a smile example, load plugin and call any number. My many-hour attempts did not lead to the result. Please give an example.(((
  8. edossantos
    Jun 27, 2007
    893
    66
  9. Umka
    Wednesday
    5
    I wrote about this example above. It does not work the calls do not work through the command line. And this example is not built correctly. Asked the smallest example it seems impossible to get? Plzzz. If I manage to write, I will lay out a very easy example of working with your API for everyone. Since your example is very confusing and the documentation leaves much to be desired.
