Integration with PBX
Discussion in '3CX Phone System - General' started by thomas_nagels, Jul 24, 2008.
  1. thomas_nagels
    Jul 24, 2008
    We have a KPN VOX DAVO I pbx that we want to connect over the internet to a 3CX SIP server.
    The pbx supports voip, but we wonder if anyone has succesfully done this?
    Kind regards,
    Thomas
  2. Henk
    Henk Member
    Nov 13, 2007
    250
    That is an ISDN box is it?
    We need to know if it can be setup as a gateway, do you got some manuals, i know it is a dutch thing but I can read dutch so happy to have a look.
    The way it might work is:
    KPN box functions as a gateway to your ISDN lines, allowing ISDN incoming calls and hands them off to 3CX. Try setting 3CX up as an extension on your KPN box.
    3CX becomes your main PBX and routes calls either to your KPN box or your VoIP provider.
    A manual or something would be handy.
    H.
