Integrations will not select - Pro Licence
Discussion in '3CX Phone System - General' started by alex22alex, Sep 5, 2017.
  1. alex22alex
    Jun 11, 2008
    38
    I dont seem to be able to select integrations on any of my extensions. I am on V15.5.5 and i have a Pro licence i have only recently upgrade but i have restarted everything and it still not selectable.
    I have tried creating new test extension just with 3cx phone selected as the provisioning.
    I have tried deleting the integration and re-downloading via the 3cx UI
    Checked the forum but the other other similar thread seems to be someone without pro.
    Is there anything special that needs to be done to get the integrations to be selectable ?
    Thanks. Alex
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,341
    535
    Hello @alex22alex
    Please navigate to settings / Licence and click Edit and then OK. Then try enabling the integration again
